hi,
is the pair style hybrid overlay only applicable for conservative force field.I am having problem in implementing both the granular and the attaractive part of the lj96 potential …
any help is highly appreciated
regards
toto
hi,
regards
toto
No, you can do it as long as you make everything consistent. Be wary of the force discontinuity from the dashpot if you’re using hooke/history. Attractive potentials and it don’t play nice together.
hi eric thanks…but when I am putting granular style along with the lj96/cut it’s saying wrong arguments for the granular style…whereas I have given the style arguments properly
hi eric thanks..but when I am putting granular style along with the
lj96/cut it's saying wrong arguments for the granular style..whereas I have
99.99% of time, when LAMMPS tells you, that your input is incorrect, this
input is indeed incorrect.
Post the declaration of the pair_style and pair_coeff piece of your input script.
