pair style MEAM requires newton pair on
Hello all,
When using MEAM potential (with gpu) I got an error message "pair style MEAM requires newton pair on". But by default the newton pair is set on. Could you help?
The input file is:
Hello all,
no. when you enable the GPU package from the command line, the default
is changed.
http://lammps.sandia.gov/doc/package.html
Could you help?
did you see anywhere in the LAMMPS documentation, that MEAM has GPU support?
there isn't, because it doesn't. so there is no point in trying.
Thanks, Axel. That's right. I assumed MEAM supports gpu as EAM does so.
Chunguang
