pair_style table WARNING
Dear lammps users,
I get my table potential files via pair_write command and when I use these table files in my simulation, there is a WARNING: 59 of 3000 force values in table are inconsistent with –dE/dr. I searched the manual but didn’t find explanation for this WARNING.
Could you please tell me how to let all force values consistent with –dE/dr? And why do I get this WARNING?
Thank you so much.
Best wishes.
Lily
Dear lammps users,
​this test was added to LAMMPS in order to identify tables where energy and
forces don't match.
you should almost always get this warning, usually just warning you about 1
point, since most potentials have at least one turning point.
it is not a very good test, since it frequently prints false positives, due
to truncation and rounding in the table files.
when you generate your potential tables via pair_write you should not
worry, if your corresponding analytical potential input is working fine.
​sometimes, you can tweak this by changing the number of tabulation points.
axel.​
