pairwise interactions between bonded atoms
Hi, I am having problems where I get an error:
“ERROR on proc 0: Bond atoms 1905 1906 missing on proc 0 at step 10”
presumably because there are some massive forces acting somewhere in the system which I need to track down. One thing I was wondering about (just to eliminate this as a possible problem) was whether by default pair wise forces acting between a type of atom still act between atoms which are bonded. If so, is there a way to make it so this doesn’t happen? (and if not, is there a way so that it can happen?).
Thanks, Henry
Some possible causes of error as I have had this before.
  1. Not minimizing the system before the run
  2. Too large of a timestep
Michael Goytia
Graduate Student
University of Utah Chemistry Department
This might interest you: http://lammps.sandia.gov/doc/special_bonds.html
And by the way, you can add “fmax” and “fnorm” to your thermo output to monitor forces in your system.
Arthur
