dear emily,
Dear Lammps users,
I wonder if any one can make some comments about these questions:
In calculating the pairwise interactions (in one of related cpp files such
as pair_lj_cut_coul_long.cpp) why there is no periodic boundary condition
applied in wrapping the distances? (I mean once the delx, dely, and delz btw
it is not needed. lammps uses a particle decomposition
and each node has "owned" and and "ghost" atoms. in
the case of just having a single domain (one processor),
those ghost atoms are the periodic images. this way
lammps is not bound in any way by minimum image
conventions and can handle cutoffs larger than half the
shortest box diameter.
i&j are calculated there is not any conditional statement such as *if
delx<-boxl/2* .... & *if delx>boxl/2...*)
I have looked at all the pairs that pairwise interactions are calculated for
in an example of a system including 300 atoms. I printed all the pairs that
are listed (from the neighbor list) for the calculations,
Firstly, I found out there are atoms with ids higher than 299 in the list.
yes, of course. those are the ghosts. see the variables atom->nlocal
and atom->nghost.
(For instance atom number 500 or 600 or such). can anyone please tell me
what are these?
see above.
i have to remark that it is very dangerous to look
at a code and not look at the documentation and
the papers that explain how it works.
Secondly, If I don't use the neighbor list and simply loop over all atoms
that are in cutoff (in a self-written program), let's say I am finding all
those that are in the attraction with atom No. "0", there would many many
more atoms!! why is this happening. If the neighbor list is making the code
more efficient, it should not affect the pairs existed in the cutoff, right?
all are there. you are not accounting for newton's
third law in your code apparently (and thus doing
twice as many force calculations).
mind you the "newton on/off" setting in LAMMPS applies to ghost
atoms only. for "local" atoms, the distinction is between a "half"
and a "full" neighbor list.
otherwise the results will be different (as I found the forces different
with lammps procedure and with my own simple example of looping over atoms
as below)
for (int i=0; i<natom-1; i++)
for (int j=i; j<natom; j++)
delx=... dely=... delz...
if (delx> box/2)... if (delx<-box/2)... etc
rsq=delx^2+dely^2+delz^2
if (rsq< cutoffSqr)
calculations ....
I appreciate any help/comments on these
ouch. this code fragment shows that you
still have to learn a lot about (efficient, parallel) MD.
you can find a quick summary of how to go from
a naiive MD implementation (like yours) to something
more efficient and parallel (up to using a cell list) in
this presentation (and also code examples for everything).
http://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxha29obG1leXxneDo1OTQ0NTkzM2M1ZmY4ODA3&pli=1
and then i *strongly* suggest you read up the rest
about verlet lists and all the tricks of the trade in
a proper text book and steve's papers on the fundamental
ideas in the LAMMPS parallelization. failing to do
so will just make you misunderstand the code over
and over again.
cheers,
