Parameters affecting the fix thermal/conductivity command
DEar lammps users,
Does anyone know what parameters affect the output of fix thermal/conductivity command?
My results are all zero. Is it a problem related to the choice of units?
Nima Pirouzmand
Try the example script in examples/KAPPA.
Actually, I started from the example and modified it for a bilayer material.
Nima
well if the example worked and your script doesn’t then you need to debug
what happened. Reading the doc page (carefully) for any command you
modified is a good place to start.
