Particles are not flowing during quasistatic shear deformation
Dear all
My name is Divas and I am trying to perform a simulation regarding “quasi-static shear deformation” on a 2D system of athermal disks. I am using lammps version of July 2021.
I have a 2D triclinic system of 8192 particles with particle diameter 1.0 and 1.4, with equal mass 1.Initially the tilt has been kept as 0.0 for xy , xz and yz.
Initially I created a box and randomly generate the particles. The particles are interacting via a linear elastic spring model. I have relaxed the system by using minimization technique FIRE. After the energy minimization , the overlapping between the particles got removed. the average total force on the particle and the kinetic energy of the system are of order 1.0e-10 and 1.0e-18 respectively.
After this process , I am trying to implement “Quasistatic shear deformation” and trying to implement LEES EDWARD boundary conditions. While doing so I am trying to implement an incremental strain of 0.0001 over the boundary of the box in xy plane. Now as the system is getting deformed under shear, the boundary of the box are moving but the total velocity of the particles are not changing. The total shear stress on the system is getting reduced too. The particles should flow with the shear deformation.
I am not able to understand the reason for the same. Any help is appreciated.
I have attached the input script to apply shear deformation and the data file of the particles. I am using granular pairstyle to implement the linear elastic spring model with stiffness 1000. I am using fix_deform delta (keyword) to apply the strain increment. The area packing fraction of the system is 0.9 This is the code I am using:
units si #si units of parameters
atom_style sphere
dimension 2
newton off
comm_modify vel yes
read_data data.stiffness_1000
group 1 type 1
group 2 type 2
set type 1 mass 1
set type 2 mass 1
neighbor 1.2 bin
neigh_modify delay 0 every 1 check no
comm_modify vel yes
pair_style granular
pair_coeff * * hooke 1000.0 00.0 tangential mindlin 0.0 1.0 0.0 damping mass_velocity
compute peratom all stress/atom NULL pair
compute p all reduce sum c_peratom[1] c_peratom[2] c_peratom[3] c_peratom[4]
variable area equal (102*102)
variable press equal -(c_p[1]+c_p[2])/v_area
variable sigmaxy equal -c_p[4]/v_area
variable kinetic equal ke
fix 3 all enforce2d
timestep 0.0001
variable i loop 1000
label loop
fix 1 all deform 1 xy delta 0.0001 remap v units box
thermo 1
thermo_style custom step ke v_press v_sigmaxy
dump 50 all custom 1 *.stress_strain id type diameter x y z vx vy c_peratom[1] c_peratom[2] c_peratom[3] c_peratom[4]
dump 40 all atom 100 shear_aqs.dump
dump_modify 50 sort id
run 1
undump 50
next i
jump SELF loop
regards
Divas Singh Dagur
Hi, does your log file report: “WARNING: No fixes with time integration, atoms won’t move”? Maybe you want fix nve/sphere?
dear sir/madam
thank you for your suggestion. I applied the same and I can observe the change in kinetic energy.
