I am trying to use python to run a simple LAMMPS simulation where I modify the force on each individual atom in a unique way. However when I try to modify the force using both extract_atom() and gather_atom()/scatter() neither one appears to modify the force. I am fairly sure it is not working because I set the force to 0 just to test it and am still having atoms move as if forces were applied. Below is a snippet of what I am trying
tmp_force = lmp.extract_atom(“f”,3)
for idx in range(n_atoms):
for jdx in range(3):
tmp_force[idx][jdx] = 0
Run simulation a single step
lmp.command(“fix simul all nve”)
lmp.command(“run 1”)
And the results are
simulation step: 0
Atom: 1
force: -0.9984898859777808
position: 0.0
force: 0.0015101140222192285
position: 0.0
force: 0.0
position: 0.0
simulation step: 1
Atom: 1
force: -0.9982779080583614
position: -1.248112357472226e-05
force: 0.0016166350850116125
position: 1.887642527774036e-08
force: 0.0
position: 0.0
where I have only included the first atom as well as the initial forces it feels
To my understanding extract_atom() is essentially a pointer to the actual lammps variable and changing the value in the python script should change it in LAMMPS as well. I get the same results if I try using the gather_atom/scatter technique as well.
Any help would be appreciated, thanks
