I am trying to run the same simulation several times saving the output files into sub-directories of my working directory, however the several codes and commands I had been trying to use causes the job to be cancelled. I am using Torque workload manager with the Cluster of Workstation - COW, what sort of scripting language shall I implement into my batch script for the sake of saving the output files?
Thank you,
Regards
Ascanio
i think you are posting to the wrong mailing list. this seems to be a
question for the torque mailing list at best, but you should first and
foremost consult with the people operating your cluster.
