Peel strength
Good day!
Is there a fix/compute that can be used to peel monolayer graphene off of a crystal?
Depends on what kind of peeling you are looking at: constant displacement (or velocity, rate) or constant load. You can use fix move, velocity set commands for the former, or fix set force for the later.
Ray
