Per atom temperature
Dear all:
I am trying to obtain temperature distribution of my system (actually temperature/atom).
According to the previous discussions in the mail list, I found that researchers are using different ways around this issue:
1- Defining a constant parameter to the “compute ke/atom”;
2- Using “compute temp/chunk” command;
3- Using “compute temp/profile” command.
Nevertheless, I cannot manage to find the proper procedure. I would be thankful to receive your guides.
Many thanks,
Nader
If you want just the temperature/atom, you can do a compute ke/atom and then divide out the appropriate degrees of freedom in a per-atom variable, and dump this to a dump file. Then you can post-process this dump file to plot the info.
If you want a temperature profile, you’ll need to use chunks.
