I launched a simulation of a tensile test on a tiny beam. But I got only 0 for the average stress and for each step. I think that i have a fracture very soon but actually, I tried with very small time step without results and i work already with the smallest units. Moreover, I display on matlab the atomis distribution at the end and at the beginning of the beam and it seems that the each extremity isn´t linked with the middles_atoms, as the fracture existed before the try.I checked the units of my parameters many times and they are good.
Maybe I forgot some information to add at my input file ?
Thanks you for your consideration
Simon Bourreau
Here is my INPUT file :
units nano
boundary s s s
atom_style peri
atom_modify map array
neighbor 0.001 bin
lattice sc 0.3615
#define all the parts
region beam block 0 36.15 0 2.169 0 2.169 units box
create_box 1 beam
create_atoms 1 region beam
region leftbc block 0 1.0845 0 2.169 0 2.169 units box
group leftbc region leftbc
region rightbc block 35.0655 36.15 0 2.169 0 2.169 units box
group rightbc region rightbc
group boundary union leftbc rightbc
group middle_atoms subtract all boundary
pair_style peri/eps
pair_coeff * * 37000 27750 1.0846 30 0.25 40
set group all density 8960e-6
set group all volume 0.047241
compute peratom middle_atoms stress/atom NULL
compute sigmaxx middle_atoms reduce sum c_peratom[1]
variable sigmavolxx equal c_sigmaxx/(0.94*vol)
fix 1 rightbc move linear 1.8075 0 0 units box
fix 2 leftbc move linear -1.8075 0 0 units box
timestep 0.005e-3 #0.005
thermo 100
thermo_style custom step v_sigmavolxx lx temp ke
dump 1 all custom 50000 peri_6_nano_eps_res.txt id x y z
dump_modify 1 append yes
run 50000
