Peridynamics PMB and LPS source
Hello Users,
I’m looking over the PMB and LPS peridynamics source and noticed that the PMB (pair_peri_pmb.cpp) spring force is calculated:
line 243, pair_peri_pmb.cpp
rk = (kspring[itype][jtype] * vfrac[j]) * vfrac_scale * stretch;
So the spring force depends on the spring constant between bonds i-j, however, in the LPS source, the spring force is calculated as:
line 289, pair_peri_lps.cpp
rk = ( (3.0 * bulkmodulus[itype][itype]) -
(5.0 * shearmodulus[itype][itype]) ) * vfrac[j] * vfrac_scale *
( (omega_plus * theta[i] / wvolume[i]) +
( omega_minus * theta[j] / wvolume[j] ) ) * r0[i][jj];
rk += 15.0 * ( shearmodulus[itype][itype] * vfrac[j] * vfrac_scale ) *
( (omega_plus / wvolume[i]) + (omega_minus / wvolume[j]) ) * dr;
the bulk modulus and shear modulus is just of the “itype”. Shouldn’t the LPS modulus values depend on the i-j bond type, so "bulkmodulus[itype][jtype] and shearmodulus[itype][jtype]?
Thanks for the input!
Hello Users,
I'm looking over the PMB and LPS peridynamics source and noticed that the
the bulk modulus and shear modulus is just of the "itype". Shouldn't the
it looks like it, but if you look around some more, there are parts
where it seems, that it is more-or-less assumed, that there is only
one type of atom.
all the peridynamics inputs that i have come across so far (which is
not exhaustive), had only one kind of material, i.e. used a statement
pair_coeff * * [...]
and in that case, these mixups wouldn't matter. there are also some
confusing statements for energy contributions.
changing this would require either a) that it is done by a
peridynamics expert or b) that it is done based on suitable example
inputs where it would be easy to verify individual component
contributions.
for the time being, i would recommend to assume, that only one kind of
material at a time can be modeled with the peridynamics pair styles.
Hi Axel,
Thanks for the reply. The points you bring up are good and I’ve also considered them. Unfortunately, I haven’t had much luck in replies from the peridynamics folks. I am pretty positive that the PMB model is correct but the other is not.
Thanks again for your reply.
Cheers
