poisson ratio for Nickel using EAM
Dear Lammps users,
I am doing a simple test of uniaxial loading on single crystal nickel to measure the poisson ratio for one EAM potential of nickel
I could not get the suggested result of 0.30 from https://sites.google.com/a/gmu.edu/eam-potential-database/Ni.
what I am getting is poisson ratio start from 0.4 and gradually changing with higher tension strain applied.
The way I am doing it is using fix_deform + npt (pressure on directions perpendicular to loading is controlled to be 1 atm), input file is as follows, I appreciate if anyone could give me suggestions how to do it.
atom_style atomic
neighbor 2 bin
neigh_modify delay 1
lattice fcc 3.52 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region box block -20 20 -20 20 -2.5 2.5
create_box 2 box
create_atoms 1 box
mass 1 58.71
mass 2 58.71
pair_style eam
pair_coeff **/software/lammps/lammps2/potentials/Ni_u3.eam
compute new all temp/deform
velocity all create 300 887723 temp new
compute PE all pe/atom
compute KE all ke/atom
compute stress all stress/atom pair
compute p all pressure new
thermo_style custom step temp pe etotal c_p[1] c_p[2] c_p[3] lx ly lz vol press
fix 1 all npt temp 300 300 1 x 1.01 1.01 5 z 1.01 1.01 5 couple none
timestep 0.001
thermo 200
thermo_modify temp new
dump overall all cfg 5000 all_*.cfg id type xs ys zs id
fix systemminimize all box/relax iso 0 nreset 5 vmax 0.001
minimize 1E-10 1E-10 2000 2000
run 1000
fix deform1 all deform 1 y delta 0 2 remap x
timestep 0.001
run 40000
Maybe Jon Zimmerman has an idea (CCd).
