Hi All,
I am working on a system of swm4-ndp water model in a channel. As a start, I followed the LAMMPS tutorial in the drude package for simulating the bulk with periodicity in all directions. Everything works fine. Now, I’m confining the water between upper and lower walls of atoms in an fcc lattice. So the box is non-periodic in z-direction. Now, this is the challenge I face and where I need your help:
variable TK equal 300.0
variable TDK equal 1.0
variable PBAR equal 1.0
fix TEMP all langevin/drude ${TK} 100. 1256 ${TDK} 20. 13977 zero yes
fix NPH ATOMS rigid/nph/small molecule iso ${PBAR} ${PBAR} 100
These the command to use for an NPT simulation. But since I will be running an NVT simulation in my case here, I don’t know how to go about it. The rigid/nvt/small is my natural choice but cannot be used with fix langevin. The fix langevin is already thermostating the core and drude particles. So, I don’t know what commands or LAMMPS strategy to use here. I’ll appreciate some advice. Thanks.
