Poly-disperse spheroids using atom_style atomic?
In the example on the movies page: “Poly-disperse spheroids for diffusion and viscosity”
It uses the atom_style sphere, but does not assign a radius to the particles, but instead controls the size by the LJ cutoff.
Could this same model be run/converted to use the atom_style atomic?
Frank
No, fix srd requires that “big” particles have a torque. It bypasses the “normal” pair style processing for the “solvent” particles.
If fix srd is removed, then atom_style atomic would be fine?
Then nothing would move the type 4 atoms and taking those away would remove your solvent.
