Polymer becomes immobile when center of mass constained
I am trying to simulate the interface between an amorphous polymer melt and a rigid graphene sheet but I am finding the polymer seems to “freeze” and become completely immobile during the NVT run, despite the thermo output data showing normal temperature and kinetic energy throughout. In my simulation I am using GAFF parameters for both the polymer and graphene, Nose-Hoover thermostat and “fix recenter” command to constrain the center of mass of the polymer.
For debugging, I have created a small test system containing a single polymer chain and a graphene sheet. I have tried rerunning using different thermostats and found the same problem occurring with Berendsen and velocity rescale but Langevin seems to work fine. I also noticed that the polymer doesn’t “freeze” when I don’t include the fix recenter command, however I need to prevent system drift in order to study diffusion properties.
Any insight into why this is happening would be much appreciated. I have attached the data file, force field files and input script.
Many thanks,
Nisha
(LAMMPS version: 29Aug2024)
polymer_graphene.data (224.2 KB)
run_nvt.in (1.2 KB)
system.in.init (333 Bytes)
system.in.settings (2.3 KB)
Fix recenter does not do that. It merely shifts the coordinates so that the center of the fix group remains in place. So it is not a constraint, but using a different point of reference. In fact, you cannot have a “position constraint”, all that you can do is a position restraint and that can be done for a group with fix spring or for individual atoms with fix spring/self.
This hints at being a victim of the so-called “flying ice cube syndrome” (search the forum for more details on that). Fix recenter does not solve that, but only hide it.
