Hello all,
The polymer system is equilibrating well with fix nve.With fix langevin and fix nve thr program is running without any error, but even after the run is complete the system is stiff, hardly displaced from equilibrated position.Is there any other requirements we are supposed to fulfill with fix langevin command.
Any advice or help would be greatly appreciated.
Thankyou
Andri
#lammps command
variable r equal floor(random(90,9850658,900))
units real
boundary f f f
atom_style full
bond_style fene
pair_style lj/cut 1.12246204831
read_data data1.polymer
bond_coeff 1 15.0 2.0 1.0 1.0
special_bonds lj 0.0 1.0 1.0
pair_modify shift yes
pair_coeff 1 1 1.0 1.0 1.12246
pair_coeff 2 2 1.0 1.0 1.12246
pair_coeff 1 2 1.0 1.0 1.12246
Only the groupB(wall) atoms are immobile.
#group mobile molecule <> 92 219
group groupB molecule <> 1 90
group mobile subtract all groupB
group polyA molecule <> 92 218
print “--------- beginning equilibration ---------”
velocity groupB set 0.0 0.0 0.0
fix 2 groupB setforce 0.0 0.0 0.0
timestep 0.5
group one id 219
velocity one set 0.0 0.0 0.0
fix 10 one setforce 0.0 0.0 0.0
velocity polyA create 1.2 $r
velocity polyA set NULL NULL 0.0
#fix fxlan mobile langevin 1.2 1.2 1.5 $r
fix fxnve polyA nve
run 500
reset_timestep 0
unfix 10
#Run
fix freeze groupB rigid single force * off off off torque * off off off
fix 4 mobile setforce NULL NULL 0.0
region 20 block -0.5 0.5 -0.5 0.5 0.0 0.0
fix 6 mobile addforce 5.0 0.0 0.0 region 20
#velocity mobile create 1.2 $r
velocity mobile set NULL NULL 0.0
fix fxnve mobile nve
timestep 0.1
dump 1 all custom 1000 new.lammpstrj id mol type x y z ix iy iz
run 300000
unfix 4
unfix freeze
unfix 6
reset_timestep 0
clear
