I need to be able to calculate the mesh size (pore size) in between the
chains in my (end-linked) polymer network using my LAMMPS data. Does anyone
have any experience doing this either directly in LAMMPS or in a secondary
software package?
Sam,
How do you define the mesh size or pore size?
Do you mean the number of bonds in a loop?
If so, you can try the "simple_cycles()" or "cycle_basis()" functions
in networkx.
http://networkx.lanl.gov/reference/generated/networkx.algorithms.cycles.simple_cycles.html
From this web page:
"A list of circuits, where each circuit is a list of nodes, with the first :
and last node being the same. :
Example: :
>>> G = nx.DiGraph([(0, 0), (0, 1), (0, 2), (1, 2), (2, 0), (2, 1),
(2, 2)]) :
>>> nx.simple_cycles(G) :
[[0, 0], [0, 1, 2, 0], [0, 2, 0], [1, 2, 1], [2, 2]]"
Sam, in this example, the 2nd entry [0, 1, 2, 0] is a loop containing 3 atoms.
This is an unrealistic example for a molecular system because the
other loops are too small (self-loops, or pairs of atoms connected by
multiple bonds). But hopefully it shows how to do it.
--- sample code ---
First, save create a data file for your system, extract the "Bonds"
section and load it into networkx. We covered this in an earlier post
a few days ago:
http://sourceforge.net/mailarchive/message.php?msg_id=29760749
...Then you can iterate through all of the loops in your system and
print out their lengths this way:
cycles = nx.simple_cycles(G)
for cycle in cycles:
print('Number of atoms in loop is: '+str(len(cycle)-1))
1
3
2
2
1
Warning: You will have to take care to eliminate loops which are
compositions of smaller loops. (It might also be necessary to embed
your network onto a plane. I'm not sure. You will have to figure
this out.)
After thinking about it further, perhaps you should use the
"cycle_basis()" function instead.
Take a look at:
http://networkx.lanl.gov/reference/generated/networkx.algorithms.cycles.cycle_basis.html#networkx.algorithms.cycles.cycle_basis
(The picture you showed me was not very planar. It was pretty, though.)
Good luck
Andrew
---- forwarded from earlier email correspondence ----
Hi Andrew,
I am looking for some more help with my analysis. I was wondering if you
would be prepared to help.
I want to know how to find the number of a) loops b) loose ends and if
possible the functionality of nodes (by nodes I mean the particles linking
ends of chains, not every node on the graph). Do you know of some nice
algorithms (sam) that could help me do this instead of me just looking at
the outputted file and counting them.
------- loops -------
For the loops ("cycles"), have you tried using the "simple_cycles()"
command in networkx?
For example, once you have created a graph G from the "Bonds" section
of you data file (previous email), you could use
num_cycles = len(cycles) #<-- counts the number of loops
If you like, you can check the size of each cycle and throw away small
or trivial cycles first, for example using code like this:
min_size_cycle = 3
i=0
while i < len(cycles):
cycle = cycles[i]
if len(cycle)-1 < min_size_cycle:
del cycles[i]
else:
i += 1
-------- ends --------
Perhaps there's an easier way to count the ends ("terminal nodes" or
"external nodes"), but would this work?
ends = []
for n in G.nodes():
if len(G.neighbors(n)) < 2:
ends.append(n)
num_ends = len(ends)
If that does not work, try replacing "for n in G.nodes():" with
"for n in dfs_preorder_nodes(G):"
