Position of members of cluster of particular size
Hi everyone,
Is it possible to get the time series positions data of members of the cluster of a fixed size?
Exporting the position vectors of a selection of atoms can be easily done through OVITO’s file export functions.
Could you tell us a little bit more about your model? What’s the criterion you use to identify the particles that are part of the cluster? Or did you use the Cluster analysis modifier in OVITO?
Hi Thanks for you reply .
I was able to write a program to get the data.
