Here I want to report a problem (possibly a bug) in using tip4p together with verlet/split for LAMMPS version 24 May 2013 (I’ve also tried 11Jul13, and it is the same)
Before showing the input files (the in files are listed as below, with the coordinate in the attachements), I’ll describe the problems generally.
The systems is water droplet on graphene. With Dreiding like force field and rigid water model, I tried the following 3 set ups
- tip3p for water, with verlet/split.
- tip4p for water, with just verlet
- tip4p for water, with verlet/split.
, with the following run command
mpirun /apps/lammps/24May13/lmp_openmpi -screen scr.log -in in -reorder nth 4 -partition 4 4
(for run with run_style verlet, the following cmd was used
mpirun /apps/lammps/24May13/lmp_openmpi -screen scr.log -in in )
While the first two runs well, the last one, in the file scr.log.1, I got the following error after the minimization was finished,
ERROR on proc 0: TIP4P hydrogen has incorrect atom type (…/pppm_tip4p.cpp:490)
In my mind, I think this is probably a bug as the first two set ups word well.
here is the in file for tip4p for water, with verlet/split, the setting for the first 2 are commented,
water between two graphite layers: looking for the minimum pressure situation
System and potential definition
atom_style full
processors * * * part 1 2 multiple
the above line wasn’t used when run without partition
read_data ./water-filled-filtered
pair_style lj/cut/tip4p/long 1 2 2 2 0.1546 10.0
for tip3p
pair_style lj/cut/coul/long 10.0
bond_style hybrid morse harmonic
C-C bond
bond_coeff 1 morse 4.964 2.1867 1.418
O-H bond
bond_coeff 2 harmonic 19.5138 0.9572
angle_style hybrid cosine/squared harmonic
angle_coeff 1 cosine/squared 2.9084 120.0
angle_coeff 2 harmonic 2.3850 104.52
dihedral_style charmm
dihedral_coeff 1 0.1302 2 180 0.0
pair_coeff for units metal
pair_coeff * * 0.0 0.0
pair_coeff 1 1 8.0338e-3 3.1589
pair_coeff 1 3 3.0e-3 4.01
pair_coeff 1 2 0.0 0.0
pair_coeff 2 2 0.0 0.0
pair_coeff 2 3 0.0 0.0
pair_coeff 3 3 4.21e-3 3.3611
special_bonds dreiding
mass 1 15.9994
mass 2 1.0080
mass 3 12.0
kspace_style pppm/tip4p 1.0e-5
for tip3p
kspace_style pppm 1.0e-5
neighbor 2.0 bin
global group definition
group gra type 3
group oxygen type 1
group hydrogen type 2
group flow type 1 2
global output definition
compute tmpall all temp
compute flow_temp flow temp
compute gra_temp gra temp
compute flow_comtemp flow temp/com
variable define
nowm : number of water molecules
variable nowm equal count(oxygen)
Set gra to be rigid
thermo_style custom step cpu etotal pe ke
thermo 2000
thermo_modify flush yes
minimization
minimize 1.0e-15 1.0e-15 10000 10000
equilibrate
velocity gra create 298.0 35281345 temp gra_temp
velocity flow create 298.0 35281345 temp flow_temp
fix 3 flow nvt temp 298.0 298.0 0.2
fix_modify 3 temp flow_comtemp
fix 4 gra nvt temp 298.0 298.0 0.2
fix_modify 4 temp gra_temp
fix g1 gra momentum 1 linear 1 1 1
fix 31 flow shake 0.001 20 1000000 b 2 a 2
dump 1 all atom 100 atom.lammpstrj
thermo 100
timestep 2.0e-3
run_style verlet/split
for verlet
run_style verlet
run 200
Best
Ming
tip4p.rar (481 KB)
