hello I’m back.When I tried to compress a large number of TIP4P water molecules confined between two copper walls in LAMMPS, using one of the copper walls as a piston, I encountered a “pppm out of range” error. I would like to know how I can resolve this error. Also, after enabling the SHAKE constraint, it only recognizes “frozen” and not “size 3”. Is this normal?
I cannot upload attachments.Here is my script and data.
atom_style full
boundary p p f
bond_style zero
angle_style zero
read_data combined1217.data
change_box all z final -10 400
fix zwall all wall/reflect zlo -9 zhi 399
pair_style hybrid lj/cut/tip4p/long 1 2 1 1 0.1546 12 eam/alloy
kspace_style pppm/tip4p 1.0e-4
kspace_modify slab 3.0
neighbor 5.0 bin
neigh_modify delay 0 every 1 check yes one 20000 page 200000
pair_coeff 1 1 lj/cut/tip4p/long 0.008035 3.1589
pair_coeff 1 2 lj/cut/tip4p/long 0.0 0.0
pair_coeff 2 2 lj/cut/tip4p/long 0.0 0.0
bond_coeff 1 0.9572
angle_coeff 1 104.52
pair_coeff * * eam/alloy Cu.eam.alloy NULL NULL Cu
pair_coeff 1 3 lj/cut/tip4p/long 0.064658 2.72808
pair_coeff 2 3 lj/cut/tip4p/long 0 0
timestep 0.001
region culow block INF INF INF INF INF 0 units box
region cuhigh block INF INF INF INF 20 INF units box
group water type 1 2
group cu type 3
group cu2 region culow
group culow intersect cu cu2
group cu1 region cuhigh
group cuhigh intersect cu cu1
velocity culow set 0 0 0
velocity cuhigh set 0 0 0
fix fix_wall_bot culow setforce 0 0 0
fix s water shake 1.0e-4 100 0 b 1 2 3 4 a 1
fix 3 water nve
variable phi equal 0.5PI
variable Area equal lxly
variable Const equal 6.2415e-7
variable N_cuhigh equal count(cuhigh)
variable Freq_GHz equal 5.0
variable Omega equal 2.0PIv_Freq_GHz*1.0e-3 # rad/ps
— smooth ramp envelope: 0 → 1 over Nramp steps, then stay 1 —
variable env equal ramp(0.0,1.0)
variable Amp0_bar equal 1200.0
variable Amp_bar equal v_Amp0_barv_env
variable F_cuhigh equal (v_Amp_barsin(v_Omega*time+v_phi))v_Areav_Const/v_N_cuhigh
fix 4 cuhigh addforce 0.0 0.0 v_F_cuhigh
fix 5 cuhigh rigid/nve single torque * off off off force * off off on
compute zcom cuhigh com
thermo_style custom step time c_zcom[3]
thermo 200
run 200000
compute t_water water temp
compute zmin all reduce min z
compute zmax all reduce max z
compute kea all ke/atom
compute kemax all reduce max c_kea
thermo_style custom step time c_zmin c_zmax c_kemax c_zcom[3] v_F_cuhigh pe ke etotal
thermo 200
reset_timestep 0
unfix 4
variable F_cuhigh equal (v_Amp0_barsin(v_Omegatime+v_phi))v_Areav_Const/v_N_cuhigh
fix 4 cuhigh addforce 0 0 v_F_cuhigh
region r_measure block INF INF INF INF 0.0 INF units box
compute cc2d water chunk/atom bin/2d x 0.0 2.0 z 0.0 2.0 units box region r_measure
fix 6 all ave/chunk 1 5000 5000 cc2d density/number file profile_2d.txt
dump d_cavity all custom 5000 dump_cavitation.lammpstrj id type x y z vx vy vz fx fy fz
run 2000000
write_data cavitation_done.data
And my data example
LAMMPS data file via write_data, version 3 Mar 2020, timestep = 50000
61449 atoms
3 atom types
34468 bonds
1 bond types
17234 angles
1 angle types
0.0000000000000000e+00 1.0191999740000000e+02 xlo xhi
0.0000000000000000e+00 1.0191999740000000e+02 ylo yhi
-4.5000000000000000e+00 1.0750000000000000e+02 zlo zhi
Masses
1 15.9994
2 1.0079
3 63.546
Bond Coeffs # zero
1 0.9572
Angle Coeffs # zero
1 104.52
Atoms # full
18185 6062 2 5.8970000000000000e-01 5.3957494066259226e+00 5.8754376309660969e+00 2.8209827929058182e+00 0 1 0
18186 6062 2 5.8970000000000000e-01 5.2735830686406961e+00 5.8147913890156939e+00 2.8739610424513291e+00 0 1 0
62271 0 3 0.0000000000000000e+00 9.8255677659732115e+01 9.8548365577258480e+01 5.1955522701738893e+01 0 0 0
62405 0 3 0.0000000000000000e+00 1.0176880805728750e+02 9.1506355505629003e+01 5.3316407771024259e+01 0 0 0
Velocities
18185 5.8227089357707786e+00 5.4587856506269072e-03 1.5509951825935708e+00
18186 -3.3355560381315850e+00 -5.7384542532681380e+00 -5.5389124263670517e+00
62271 -6.8613483548604581e-01 -2.9379291516950130e+00 -7.7589684423795116e-02
62405 2.3810222897326483e-01 1.7816073540178468e+00 1.4950621139179232e+00
Bonds
1 1 5998 5999
2 1 5998 6000
34467 1 50602 50603
34468 1 50602 50604
Angles
1 1 5999 5998 6000
2 1 1877 1876 1878
