press/berendsen barostat problem
Dear Sirs,
I would like to ask if anyone would have some suggestion as to what
might cause the following error message from the lammps/17Feb12 version:
Dear Sirs,
bad dynamics overflowing some neighbor list.
have you equilibrated at constant volume?
have you check whether your time step is adequate?
In 3 timesteps your box volume increased 30%.
That doesn't sound like a well-behaved model.
Hi Osvalds,
First step potential energies are different in your lammps and standalone
reac outputs, while they should match quite well if you have the exact
same settings. I would advise you to check settings in your lammps
"control.test" file.
Also in your lammps output T starts a 0, while that of your reac output
starts at 1500K. Another thing, your Tdamp and Pdamp in your lammps input
are 250 fs and 12500 fs - which are significantly larger than usual.
These settings in my copy of the standalone reac code are 1 and 100 fs.
Ray
