press, energy, density became abnormal after a long time of NPT
Dear LAMMPS users,
I’m trying to run a simulation in NPT( 300 K and 1 atm). Everything is OK (the total energy declined gradually, the average press equilibrated at 1 atm, the temperature was fine and the density increased gradually to a stable and desired value) until the timestep reached 24000000.The total energy and press suddenly increased, the temperature fluctuated more widely and the density decreased from the stable value to a very small and unphysical value.
What caused this phenomena and how to correct it?
Thank you very much!
here is my input file:
units real
atom_style full
bond_style harmonic
angle_style harmonic
dihedral_style hybrid charmm fourier
pair_style hybrid lj/charmm/coul/long 10.0 11
kspace_style pppm 1.0e-5
pair_modify mix arithmetic
special_bonds lj 0.0 0.0 0.0 coul 0.0 0.0 0.8333 dihedral yes
neighbor 2.0 bin #
neigh_modify every 5 delay 5 check yes #
----------------- Atom Definition Section -----------------
read_data 128375537553755.data
#read_restart 128newnpt200000.restart
----------------- Settings Section -----------------
include “5CBs.in.settings”
#----------------- Minimize -----------------
thermo 5
#thermo_style custom step temp pe ke etotal evdwl ecoul elong press density
thermo_style custom step temp pe etotal evdwl ecoul elong press vol density
fix min all box/relax iso 1.0 vmax 0.01
minimize 1.0e-6 1.0e-8 1000 10000
reset_timestep 0
restart 500000 128newnpt*.restart
----------------- Run Section -----------------
timestep 2 #1 fs=10^(-15) s
velocity all create 300 12345678 loop geom
thermo 2000
dump 1 all custom 15000 vmd.lammpstrj id mol type x y z ix iy iz
dump_modify 1 format 1 %10d format 2 %10d format 3 %10d format 4 %12.6f &
format 5 %12.6f format 6 %12.6f format 7 %10d format 8 %10d format 9 %10d
compute 1 all chunk/atom molecule ids once
compute 2 all inertia/chunk 1
fix intertia1 all ave/time 5000 1 5000 c_2[*] file tmp.out mode vector &
title1 “Ixx,Iyy,Izz,Ixy,Iyz,Ixz”
fix 1 all nve
fix tempres all temp/rescale 1 300 300 1 1
run 1000000
unfix 1
unfix tempres
fix 1 all nve
fix press1 all press/berendsen iso 1.0 1.0 1500.0 modulus 500000
run 5000000
write_data 128temres300p1.*.data
unfix 1
unfix tempres
unfix press1
fix 1 all nve
fix temp1 all temp/berendsen 300 300 1200.0
run 35000000 #35ns
write_data 19128tem300p1atm*.data
