Dear Lammps users,
I am trying to equilibrate my system at 300k and 0 bar, I suffered from a high pressure at start(~40000bar) so I used nve/lim and made box relaxation and eventually the box pressure started to drop massively, I then tried to equilibrate for a very long time and using the recommended Tdamp and Pdamp ( my time step is 0.001, Tdamp=0.1 and Pdamp=1) but the pressure kept fluctuating from -10000 bar to 10000 bar. Can you advice please what may be the reason for that?
Thanks in advance
Regards
atom_style charge
lattice custom 1 a1 6.607 0 0 a2 0 6.607 0 a3 0 0 5.982 basis 0.0 0.75 0.125 basis 0.0 0.25 0.875 basis 0.5 0.75 0.375 basis 0.5 0.25 0.625 basis 0.0 0.75 0.625 basis 0.0 0.25 0.375 basis 0.5 0.75 0.875 basis 0.5 0.25 0.125 basis 0.0 0.0658 0.1955 basis 0.0 0.9342 0.8045 basis 0.5 0.0658 0.3045 basis 0.5 0.9342 0.6955 basis 0.0 0.5658 0.8045 basis 0.0 0.4342 0.1955 basis 0.5 0.5658 0.6955 basis 0.5 0.4342 0.3045 basis 0.6842 0.25 0.9455 basis 0.8158 0.75 0.4455 basis 0.8158 0.25 0.5545 basis 0.6842 0.75 0.0545 basis 0.1842 0.25 0.5545 basis 0.3158 0.75 0.0545 basis 0.3158 0.25 0.9455 basis 0.1842 0.75 0.4455
region R1 block -1 1 -1 1 -1 1
create_box 3 R1
create_atoms 3 region R1 basis 1 1 basis 2 1 basis 3 1 basis 4 1 basis 5 2 basis 6 2 basis 7 2 basis 8 2 basis 9 3 basis 10 3 basis 11 3 basis 12 3 basis 13 3 basis 14 3 basis 15 3 basis 16 3 basis 17 3 basis 18 3 basis 19 3 #basis 20 3 basis 21 3 basis 22 3 basis 23 3 basis 24 3
mass 1 91.224
mass 2 28
mass 3 16
group 1 type 1 # zircon
group 2 type 2 # silicon
group 3 type 3 # oxygen
set group 1 type 1 charge 3.8
set group 2 type 2 charge 2.0
set group 3 type 3 charge -1.45
velocity all create 0 7928459 dist gaussian
dump atom all custom 1000 dump.coordinates id type x y z
System interatomic potential
kspace_style ewald 5e-3
pair_style born/coul/long 10
pair_coeff 1 3 1967.0 0.305004 0.0 0.0 0.0
pair_coeff 2 3 1277.0 0.227225 0.0 0.0 0.0
pair_coeff 3 3 1755.0 0.306820 0.0 0.0 0.0
pair_coeff 1 2 0.0 0.306820 0.0 0.0 0.0
pair_coeff 2 2 0.0 0.306820 0.0 0.0 0.0
pair_coeff 1 1 0.0 0.306820 0.0 0.0 0.0
timestep 0.001
thermo 100
fix 1 all nve
run 10000
unfix 1
fix 1 all nve/limit 1
run 10000
unfix 1
fix 2 all nve/limit 0.8
run 10000
unfix 2
fix 3 all nve/limit 0.6
run 10000
unfix 3
fix 4 all nve/limit 0.4
run 10000
unfix 4
fix 1 all nve/limit 0.3
run 10000
unfix 1
fix 1 all nve/limit 0.2
run 10000
unfix 1
fix 1 all nve/limit 0.1
run 10000
unfix 1
fix 1 all nve/limit 0.07
run 10000
unfix 1
fix 1 all nve/limit 0.06
run 10000
unfix 1
fix 1 all nve/limit 0.05
run 10000
unfix 1
fix 1 all nve/limit 0.04
run 10000
unfix 1
fix 1 all nve/limit 0.03
run 10000
unfix 1
fix 1 all nve/limit 0.02
run 10000
unfix 1
fix 1 all nve/limit 0.01
run 10000
unfix 1
#BOX RELAXATION
fix 1 all box/relax iso 0.0
#minimization
min_style cg
minimize 1e-25 1e-25 5000 100000
run 10000
unfix 1
#Equilibration
fix 1 all npt temp 300.0 300.0 0.01 iso 0.0 0.0 0.1
run 5000000
