printing chunkwise temperature
Hii all,
I am trying to calculate the temperature of each chunk of a system .The temperature should not contain contribution of energy from centre of mass velocity. The calculated temperature has to be printed chunkwise at different time step. For that I am using following script. I am having problem in how to print temperature of every chunk. Can anyone suggest.
compute 3 bulk chunk/atom bin/1d z lower ${dz} units box
compute tempcom bulk temp/chunk 3 temp.dat com yes
After this how to print chunkwise temperature
The statement :
fix temp_profile bulk ave/time 500 1 500 c_tempcom file temp.dat mode vector
does not print chunkwise temperature.
Regards,
Nidhi
You don’t say what the error or issue is.
The compute temp/chunk command doc page explains
that it produces both a global temperature and a global
array with the per-chunk temperatures. To access the
latter your fix ave/time would need to access the columns
of the array, something like c_tempcom[1]. So probably
you are just accessng the global scalar, not the per-chunk values.
