printing to file
Dear all
I don’t find any method in LAMMPS - 1Feb14 to output properties using “print command” (not “fix print”) to file. I want to print the properties at certain specific timesteps. These are not in regular intervals. Some minimizations are present in between.
Could you please help me to find out the way to print properties at specific timesteps to separate file?
Yours faithfully
Jeeno Jose
I don’t know if it may work, or if you already tried using some combination of the boolean “if” provided by lammps, with some combination of variables of your choice.
respectfully,
The print command can print to a file, or append to an existing
file. So if you use it multiple times (when you choose) you
can have all the output go to a file.
