Problem Calling Certain Python Modules from LAMMPS Input File
Dear LAMMPS Users,
I have been trying to call a python script from lammps (relevant portions shown below) in order to evaluate forces from a very specific potential energy surface. Even though the python script alone functions properly, when called from lammps, I run into errors of the form:
File “interp_CH4_pot_short_Brenda_modified.py”, line 13, in
from scipy.interpolate import griddata
ImportError: cannot import name griddata
ERROR: Could not process Python file (…/python.cpp:176)
Based upon a number of tests (using mock python scripts and by playing with which scipy functions I am calling), it seems as though lammps has trouble whenever I try to use the scipy.interpolate package. It does not want to load the required griddata (or other interpolate) modules. However, it does not incur any problems running non scipy interpolate functions. Is this a systematic problem loading certain modules? Are there any ideas as to why this won’t work for me? Any help or advice would be greatly appreciated!
Details:
I am using the LAMMPS Dec 7, 2015 version. Maybe later versions can do this?
Relevant Parts of Python Script (name of script is interp_CH4_pot_short_Brenda_modified.py):
#!/usr/bin/python
import sys
import os
import time
import math
import numpy as np
import shutil
import scipy
import subprocess
potgrad = np.load(‘potgrad.npy’)
gridsize = .1
gridx = np.ceil(19.2/gridsize) + 1
gridy = np.ceil(3.056/gridsize) + 1
gridz = np.ceil(5.15/gridsize) + 1
gridx = int(gridx)
gridy = int(gridy)
gridz = int(gridz)
gridcoords = np.zeros((gridx,gridy,gridz,3))
gridpot = np.zeros((gridx,gridy,gridz))
gridforce = np.zeros((gridx,gridy,gridz,3))
xc = np.linspace(-1.1,18.1,gridx) #.1 A extra on each side
yc = np.linspace(-.1,2.956231451,gridy) #.1 A extra on each side
zc = np.linspace(-2.573458221,2.573458221,gridz) #.1 A extra on each side
spacex = 19.2/(gridx-1)
spacey = 3.056231451/(gridy-1)
spacez = 5.146916442/(gridz-1)
gridcoords = np.array(gridcoords)
forcey = scipy.interpolate.RegularGridInterpolator((xc,yc,zc), -potgrad[1,:,:,:])
def force_CH4_x(x,y,z):
x_p = np.mod(x,2.856231451)
y_p = np.mod(y,4.946916442) - 2.47345822
force_x = forcey((z,x_p,y_p))
return force_x
force_2 = force_CH4_x(1,1,1)
print force_2
Relevant Call in LAMMPS Input File:
variable tz equal z[1]
variable tx equal x[1]
variable ty equal y[1]
variable force_z2 python force_CH4_x
python force_CH4_x input 3 v_tx v_ty v_tz return v_force_z2 format ffff file interp_CH4_pot_short_Brenda_modified.py
Dr. Brenda Rubenstein
Assistant Professor of Chemistry
Brown University
https://www.brown.edu/research/labs/rubenstein/home
Dear LAMMPS Users,
  File "interp_CH4_pot_short_Brenda_modified.py", line 13, in <module>
ERROR: Could not process Python file (../python.cpp:176)
to why this won't work for me? Any help or advice would be greatly
appreciated!
​my first suspicion would be that your PYTHONPATH environment variable is
not properly configured.
at any rate, below is an absolute minimum stripped down version of your
example.
file in.grid:
variable tx equal 1.0
variable ty equal 1.0
variable tz equal 1.0
file grid.py
python force_CH4_x invoke
file grid.py:
    print("in force_CH4_x")
    return 0.0
​...and those work fine for me with the current development version of
LAMMPS:​
]$ ~/compile/lammps-icms/src/lmp_omp -in in.grid
LAMMPS (23 Oct 2017)
in force_CH4_x
Total wall time: 0:00:00
Details:
this?
​using a two year old version of LAMMPS is never a good idea, but it is
particularly bad for interfacing to python since a lot of bugfixes and
improvements have been added since.​
