problem dumping to cfg file
I have a problem in dumping into cfg format it is showing the error :
does not look like Ju Li’s CFG format because it does
not have “Number of particles =” as its first line.
Here is my dump code from input file:
dump 37 all cfg 10 CuNano5.*.cfg id type xs ys zs id type c_ack
What does that mean ?
thanks
Vanu
Your cfg command worked just fine for me. Maybe you need to
re-install your AtomEye, or check if your script actually ran and
successfully generated cfg.
Ray
