HI All
I imported the structure of GaN using “read data” with N-total number of atoms divided in two types. Then I assigned the atoms as Type-1 (Ga) and Type-2 (N) so that I can use SW potential. My problem comes when I want to calculate the VACF (velocity auto correlation function ) of specific atoms not of all (say VACF of Ga or N at the center or at the surface)…So I was wondering if there is a trick to do this.
Z.
HI All
I imported the structure of GaN using "read data" with N-total number of
not of all (say VACF of Ga or N at the center or at the surface).....So I
you can define groups by region as well, but please see the very
recent discussion in this forum on the fundamental ambiguity problem
with such an approach (i.e. you cannot use a dynamic group) in the
context of computing the MSD. it is the same problem here.
