Dear Steve and others,
I have an old version of Lammps which I can compile and use it without any problem, but now I want to use the up-to-date lammps version but I receive the following message when I want to compile it with the same makefile I am using for the old version. I would be glad if anyone can help me to find my mistake. My makefile is also attached.
grep: angle_.h: No such file or directory
grep: dihedral_.h: No such file or directory
grep: improper_*.h: No such file or directory
make[1]: Entering directory /home/malaghem/soft/mylammps/src/Obj_donal' g++ -g -O0 -I/usr/include/mpich2 -DLAMMPS_GZIP -DMPICH_IGNORE_CXX_SEEK -DFFT_FFTW -c force.cpp g++ -g -O -I/usr/include/mpich2 angle.o atom.o atom_vec_atomic.o atom_vec_charge.o atom_vec.o atom_vec_ellipsoid.o atom_vec_hybrid.o atom_vec_sphere.o bond.o bond_hybrid.o change_box.o comm.o compute_angle_local.o compute_atom_molecule.o compute_bond_local.o compute_centro_atom.o compute_cluster_atom.o compute_cna_atom.o compute_com.o compute_com_molecule.o compute_coord_atom.o compute.o compute_dihedral_local.o compute_displace_atom.o compute_erotate_sphere.o compute_group_group.o compute_gyration.o compute_gyration_molecule.o compute_heat_flux.o compute_improper_local.o compute_ke_atom.o compute_ke.o compute_msd.o compute_msd_molecule.o compute_pair.o compute_pair_local.o compute_pe_atom.o compute_pe.o compute_pressure.o compute_property_atom.o compute_property_local.o compute_property_molecule.o compute_rdf.o compute_reduce.o compute_reduce_region.o compute_slice.o compute_stress_atom.o compute_temp_com.o compute_temp.o compute_temp_deform.o compute_temp_partial.o compute_temp_profile.o compute_temp_ramp.o compute_temp_region.o compute_temp_sphere.o compute_ti.o create_atoms.o create_box.o delete_atoms.o delete_bonds.o dihedral.o displace_atoms.o displace_box.o domain.o dump_atom.o dump_cfg.o dump.o dump_custom.o dump_dcd.o dump_image.o dump_local.o dump_xyz.o error.o finish.o fix_adapt.o fix_addforce.o fix_ave_atom.o fix_ave_correlate.o fix_aveforce.o fix_ave_histo.o fix_ave_spatial.o fix_ave_time.o fix_box_relax.o fix.o fix_deform.o fix_deposit.o fix_drag.o fix_dt_reset.o fix_efield.o fix_enforce2d.o fix_evaporate.o fix_external.o fix_gravity.o fix_heat.o fix_indent.o fix_langevin.o fix_lineforce.o fix_minimize.o fix_momentum.o fix_move.o fix_nh.o fix_nh_sphere.o fix_nph.o fix_nph_sphere.o fix_npt.o fix_npt_sphere.o fix_nve.o fix_nve_limit.o fix_nve_noforce.o fix_nve_sphere.o fix_nvt.o fix_nvt_sllod.o fix_nvt_sphere.o fix_orient_fcc.o fix_planeforce.o fix_press_berendsen.o fix_print.o fix_read_restart.o fix_recenter.o fix_respa.o fix_rigid.o fix_rigid_nve.o fix_rigid_nvt.o fix_setforce.o fix_shake.o fix_shear_history.o fix_spring.o fix_spring_rg.o fix_spring_self.o fix_store_force.o fix_store_state.o fix_temp_berendsen.o fix_temp_rescale.o fix_thermal_conductivity.o fix_tmd.o fix_ttm.o fix_viscosity.o fix_viscous.o fix_wall.o fix_wall_harmonic.o fix_wall_lj126.o fix_wall_lj93.o fix_wall_reflect.o fix_wall_region.o force.o group.o improper.o input.o integrate.o irregular.o kspace.o lammps.o lattice.o library.o main.o math_extra.o memory.o min_cg.o min.o min_fire.o min_hftn.o minimize.o min_linesearch.o min_quickmin.o min_sd.o modify.o neigh_bond.o neighbor.o neigh_derive.o neigh_full.o neigh_gran.o neigh_half_bin.o neigh_half_multi.o neigh_half_nsq.o neigh_list.o neigh_request.o neigh_respa.o neigh_stencil.o output.o pack.o pair_born.o pair_buck_coul_cut.o pair_buck.o pair_coul_cut.o pair_coul_debye.o pair.o pair_dpd.o pair_dpd_tstat.o pair_gauss.o pair_hybrid.o pair_hybrid_overlay.o pair_lj96_cut.o pair_lj_cut_coul_cut.o pair_lj_cut_coul_debye.o pair_lj_cut.o pair_lj_expand.o pair_lj_gromacs_coul_gromacs.o pair_lj_gromacs.o pair_lj_smooth.o pair_morse.o pair_soft.o pair_table.o pair_yukawa.o random_mars.o random_park.o read_data.o read_restart.o region_block.o region_cone.o region.o region_cylinder.o region_intersect.o region_plane.o region_prism.o region_sphere.o region_union.o replicate.o respa.o run.o set.o special.o thermo.o timer.o universe.o update.o variable.o velocity.o verlet.o write_restart.o -lmpich -lpthread -lfftw -o ../lmp_donal size ../lmp_donal text data bss dec hex filename 3048497 11296 336 3060129 2eb1a1 ../lmp_donal make[1]: Leaving directory
/home/malaghem/soft/mylammps/src/Obj_donal’
Mohammad
Makefile.mohammad (2.36 KB)
