Problem in compute com
I’m using lammps to calculate position of the center of mass (com) of a polymer chain. The coordinates of the atoms of the polymer are all positive. Besides, the box length is nearly 70A in each direction. However, I get negative values for x coordinate of com, and the z values more than 70A for com:
Commands:
compute comP01 Polymer com
fix comP01 Polymer ave/time 1 500 500 c_comP01[1] c_comP01[2] c_comP01[3] file Polymer.com
Output:
TimeStep c_comP01[1] c_comP01[2] c_comP01[3]
500 -35.7224 35.8898 92.5117
1000 -35.0634 36.3794 92.4888
1500 -34.9073 36.8343 92.7679
2000 -34.7589 37.1734 93.0236
2500 -34.487 37.3728 93.0588
3000 -34.0996 37.5306 93.0176
3500 -33.7963 37.679 93.0585
Upon visualization, I could’t find anything strange. Polymer chain vibrates slightly in the simulation box, as expected.
I appreciate if you can say your opinion about this problem. I’m using lammps/28Jun14. Is there anything I’m implementing wrong?
2014-11-14 5:41 GMT+01:00 Xiaolin Xu <[email protected]...>:
I'm using lammps to calculate position of the center of mass (com) of a
70A for com:
Probably, your system moved through x and z periodic walls. The com compute
uses unwrapped coordinates. So you'll have to see were this happens (maybe
during equilibration, or you create your system "outside" of the box).
Kristof
