Problem in fix vector
I have tested that the example script of in.msd in DIFFUSE directory, which is good for itself. When I just added another “run” command at the end of the script, then I got segmentation fault error when the program finished. It seems to me that there is a memory leak in the Lammps package. Further calculated results seems to be OK. When I changed N=10 to N=1 in fix vector command , it is OK. Please check the codes in the package.
What other run command did you add, and where did you add it?
fixed it - thanks
will be in next patch
