problem in makining lammps with make file that i use
i am imran, i want to install lammps(new version) at RHEL 5 with a single processor computer of 2.0Ghz. i haved installed the FFTW 2.1.5 and MPICH2-1.3.2p1. then i installed the lib files include with the lammps package atc, poems,meam etc then i use the commands
#make STUBS
STUBS is up to date appears
then i use make command to make lammps the the following lines appears
[[email protected]…436… src]# make linux
make[1]: Entering directory `/root/imran/lammps-4Apr11/src/Obj_linux’
gcc -O -i/usr/local/lib -i/usr/local/lib angle_charmm.o angle_cosine.o angle_cosine_delta.o angle_cosine_periodic.o angle_cosine_squared.o angle.o angle_harmonic.o angle_hybrid.o angle_table.o atom.o atom_vec_angle.o atom_vec_atomic.o atom_vec_bond.o atom_vec_charge.o atom_vec.o atom_vec_full.o atom_vec_hybrid.o atom_vec_molecular.o bond.o bond_fene.o bond_fene_expand.o bond_harmonic.o bond_hybrid.o bond_morse.o bond_nonlinear.o bond_quartic.o bond_table.o change_box.o comm.o compute_angle_local.o compute_atom_molecule.o compute_bond_local.o compute_centro_atom.o compute_cluster_atom.o compute_cna_atom.o compute_com.o compute_com_molecule.o compute_coord_atom.o compute.o compute_dihedral_local.o compute_displace_atom.o compute_erotate_sphere.o compute_group_group.o compute_gyration.o compute_gyration_molecule.o compute_heat_flux.o compute_improper_local.o compute_ke_atom.o compute_ke.o compute_msd.o compute_msd_molecule.o compute_pair.o compute_pair_local.o compute_pe_atom.o compute_pe.o compute_pressure.o compute_property_atom.o compute_property_local.o compute_property_molecule.o compute_rdf.o compute_reduce.o compute_reduce_region.o compute_stress_atom.o compute_temp_com.o compute_temp.o compute_temp_deform.o compute_temp_partial.o compute_temp_profile.o compute_temp_ramp.o compute_temp_region.o compute_temp_sphere.o compute_ti.o create_atoms.o create_box.o delete_atoms.o delete_bonds.o dihedral_charmm.o dihedral.o dihedral_harmonic.o dihedral_helix.o dihedral_hybrid.o dihedral_multi_harmonic.o dihedral_opls.o displace_atoms.o displace_box.o domain.o dump_atom.o dump_cfg.o dump.o dump_custom.o dump_dcd.o dump_local.o dump_xyz.o error.o ewald.o fft3d.o fft3d_wrap.o finish.o fix_adapt.o fix_addforce.o fix_ave_atom.o fix_ave_correlate.o fix_aveforce.o fix_ave_histo.o fix_ave_spatial.o fix_ave_time.o fix_bond_break.o fix_bond_create.o fix_bond_swap.o fix_box_relax.o fix.o fix_deform.o fix_deposit.o fix_drag.o fix_dt_reset.o fix_efield.o fix_enforce2d.o fix_evaporate.o fix_external.o fix_gravity.o fix_heat.o fix_indent.o fix_langevin.o fix_lineforce.o fix_minimize.o fix_momentum.o fix_move.o fix_nh.o fix_nh_sphere.o fix_nph.o fix_nph_sphere.o fix_npt.o fix_npt_sphere.o fix_nve.o fix_nve_limit.o fix_nve_noforce.o fix_nve_sphere.o fix_nvt.o fix_nvt_sllod.o fix_nvt_sphere.o fix_orient_fcc.o fix_planeforce.o fix_press_berendsen.o fix_print.o fix_qeq_comb.o fix_read_restart.o fix_recenter.o fix_respa.o fix_rigid.o fix_rigid_nve.o fix_rigid_nvt.o fix_setforce.o fix_shake.o fix_shear_history.o fix_spring.o fix_spring_rg.o fix_spring_self.o fix_store_force.o fix_store_state.o fix_temp_berendsen.o fix_temp_rescale.o fix_thermal_conductivity.o fix_tmd.o fix_ttm.o fix_viscosity.o fix_viscous.o fix_wall.o fix_wall_harmonic.o fix_wall_lj126.o fix_wall_lj93.o fix_wall_reflect.o fix_wall_region.o force.o group.o improper.o improper_cvff.o improper_harmonic.o improper_hybrid.o improper_umbrella.o input.o integrate.o irregular.o kspace.o lammps.o lattice.o library.o main.o memory.o min_cg.o min.o min_fire.o min_hftn.o minimize.o min_linesearch.o min_quickmin.o min_sd.o modify.o neigh_bond.o neighbor.o neigh_derive.o neigh_full.o neigh_gran.o neigh_half_bin.o neigh_half_multi.o neigh_half_nsq.o neigh_list.o neigh_request.o neigh_respa.o neigh_stencil.o output.o pack.o pair_airebo.o pair_born_coul_long.o pair_born.o pair_buck_coul_cut.o pair_buck_coul_long.o pair_buck.o pair_comb.o pair_coul_cut.o pair_coul_debye.o pair_coul_long.o pair.o pair_dpd.o pair_dpd_tstat.o pair_eam_alloy.o pair_eam.o pair_eam_fs.o pair_eim.o pair_gauss.o pair_hbond_dreiding_lj.o pair_hbond_dreiding_morse.o pair_hybrid.o pair_hybrid_overlay.o pair_lj96_cut.o pair_lj_charmm_coul_charmm.o pair_lj_charmm_coul_charmm_implicit.o pair_lj_charmm_coul_long.o pair_lj_cut_coul_cut.o pair_lj_cut_coul_debye.o pair_lj_cut_coul_long.o pair_lj_cut_coul_long_tip4p.o pair_lj_cut.o pair_lj_expand.o pair_lj_gromacs_coul_gromacs.o pair_lj_gromacs.o pair_lj_smooth.o pair_morse.o pair_soft.o pair_sw.o pair_table.o pair_tersoff.o pair_tersoff_zbl.o pair_yukawa.o pppm.o pppm_tip4p.o random_mars.o random_park.o read_data.o read_restart.o region_block.o region_cone.o region.o region_cylinder.o region_intersect.o region_plane.o region_prism.o region_sphere.o region_union.o remap.o remap_wrap.o replicate.o respa.o run.o set.o special.o thermo.o timer.o universe.o update.o variable.o velocity.o verlet.o write_restart.o -lmpich -lpthread -lfftw -lstdc++ -o …/lmp_linux
/usr/local/lib/libmpich.a(init.o): In function `MPI_Init’:
init.c:(.text+0x34): undefined reference to `MPL_env2str’
init.c:(.text+0x54): undefined reference to `MPL_env2bool’
/usr/local/lib/libmpich.a(initthread.o): In function `MPI_Init_thread’:
initthread.c:(.text+0x4a6): undefined reference to `MPL_env2bool’
/usr/local/lib/libmpich.a(param_vals.o): In function `MPIR_Param_init_params’:
param_vals.c:(.text+0x16): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x33): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x50): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x6d): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x8a): undefined reference to `MPL_env2int’
/usr/local/lib/libmpich.a(param_vals.o):param_vals.c:(.text+0xa7): more undefined references to `MPL_env2int’ follow
param_vals.c:(.text+0x3d3): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x3f0): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x40d): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x42a): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x447): undefined reference to `MPL_env2bool’
/usr/local/lib/libmpich.a(param_vals.o):param_vals.c:(.text+0x464): more undefined references to `MPL_env2bool’ follow
param_vals.c:(.text+0x4bb): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x4d8): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x4f5): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x512): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x52f): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x54c): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x569): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x586): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x5a3): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x5c0): undefined reference to `MPL_env2int’
param_vals.c:(.text+0x5dd): undefined reference to `MPL_env2str’
param_vals.c:(.text+0x5fa): undefined reference to `MPL_env2str’
param_vals.c:(.text+0x617): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x634): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x651): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x66e): undefined reference to `MPL_env2bool’
param_vals.c:(.text+0x68b): undefined reference to `MPL_env2bool’
/usr/local/lib/libmpich.a(param_vals.o):param_vals.c:(.text+0x6a8): more undefined references to `MPL_env2bool’ follow
/usr/local/lib/libmpich.a(mpid_vc.o): In function `MPIDI_Populate_vc_node_ids’:
mpid_vc.c:(.text+0x2b9): undefined reference to `MPL_env2int’
mpid_vc.c:(.text+0x2cc): undefined reference to `MPL_env2int’
mpid_vc.c:(.text+0x2f2): undefined reference to `MPL_env2bool’
/usr/local/lib/libmpich.a(tcp_init.o): In function `MPID_nem_tcp_bind’:
tcp_init.c:(.text+0x1dd): undefined reference to `MPL_env2range’
collect2: ld returned 1 exit status
make[1]: *** […/lmp_linux] Error 1
make[1]: Leaving directory `/root/imran/lammps-4Apr11/src/Obj_linux’
make: *** [linux] Error 2
THE MAKE FILE IS FOLLOWING
linux = RedHat Linux box, GNU gcc, gfortron, MPICH2, FFTW
SHELL = /bin/sh
compiler/linker settings
specify flags and libraries needed for your compiler
CC = gcc
CCFLAGS = -O
DEPFLAGS = -D
LINK = gcc
LINKFLAGS = -O
LIB = -lstdc++
ARCHIVE = ar
ARFLAGS = -rc
SIZE = size
LAMMPS-specific settings
specify settings for LAMMPS features you will use
LAMMPS ifdef options, see doc/Section_start.html
LMP_INC = -DLAMMPS_GZIP
MPI library, can be src/STUBS dummy lib
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
MPI_INC = -DMPICH_SKIP_MPICXX
MPI_PATH = -i/usr/local/lib
MPI_LIB = -lmpich -lpthread
FFT library, can be -DFFT_NONE if not using PPPM from KSPACE package
INC = -DFFT_FFTW, -DFFT_INTEL, -DFFT_NONE, etc, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
FFT_INC = -DFFT_FFTW
FFT_PATH = -i/usr/local/lib
FFT_LIB = -lfftw
JPEG library, only needed if -DLAMMPS_JPEG listed with LMP_INC
INC = path for jpeglib.h
PATH = path for JPEG library
LIB = name of JPEG library
JPG_INC =
JPG_PATH =
JPG_LIB =
additional system libraries needed by LAMMPS package libraries
these settings are IGNORED if the corresponding LAMMPS package
(e.g. gpu, meam) is NOT included in the LAMMPS build
SYSLIB = names of libraries
SYSPATH = paths of libraries
gpu_SYSLIB = -lcudart
meam_SYSLIB = -lifcore -lsvml -lompstub -limf
reax_SYSLIB = -lifcore -lsvml -lompstub -limf
user-atc_SYSLIB = -lblas -llapack
gpu_SYSPATH = -L/usr/local/cuda/lib64
meam_SYSPATH = -L/opt/intel/fce/10.0.023/lib
reax_SYSPATH = -L/opt/intel/fce/10.0.023/lib
user-atc_SYSPATH =
build rules and dependencies
no need to edit this section
include Makefile.package
EXTRA_INC = (LMP_INC) (PKG_INC) (MPI_INC) (FFT_INC) $(JPG_INC)
EXTRA_PATH = (PKG_PATH) (MPI_PATH) (FFT_PATH) (JPG_PATH) $(PKG_SYSPATH)
EXTRA_LIB = (PKG_LIB) (MPI_LIB) (FFT_LIB) (JPG_LIB) $(PKG_SYSLIB)
Link target
(EXE): (OBJ)
(LINK) (LINKFLAGS) (EXTRA_PATH) (OBJ) (EXTRA_LIB) (LIB) -o $(EXE)
(SIZE) (EXE)
Library target
lib: $(OBJ)
(ARCHIVE) (ARFLAGS) (EXE) (OBJ)
Compilation rules
.o:.cpp
(CC) (CCFLAGS) (EXTRA_INC) -c <
.d:.cpp
(CC) (CCFLAGS) (EXTRA_INC) (DEPFLAGS) < > @
Individual dependencies
DEPENDS = $(OBJ:.o=.d)
include $(DEPENDS)
the am unable to understand the problem, is there any body who can kindly help me in lammps installation. the makefile .linux is also attached with this mail.
kindly help me in this problem.
WAITING FOR YOUR HELP
Muhammad Imran
Ph.d research student
The Islamia Uneversity of Bahawalpur.
