Hi all,
I want to include a precipitation, a gas bubble, inside of a monocrystalline metal. Also, I want to increase the pressure of the gas bubble by varying the density of that particular group, i.e, “gas-bubble”.
To accomplish these, I’m trying to create crystal structure then deleting a spherical region and introducing gas atoms in that region. I’m doing NVE for equilibration.
But, to achieve a high pressure in the gas bubble when I’m increasing the mass density of that bubble region, I get “neighbor list overflow” error, which is quite certain. On the contrary, if I use “neighbor_modify exclude type 2” then the interactions between gas atoms with switching off. Right? Hence, could anybody please help me out in this regard?
Any comments/idea/suggestion is greatly appreciated.
Oxem
Hi all,
bubble by varying the density of that particular group, i.e, "gas-bubble".
To accomplish these, I'm trying to create crystal structure then deleting
a spherical region and introducing gas atoms in that region. I'm doing NVE
for equilibration.
But, to achieve a high pressure in the gas bubble when I'm increasing the
mass density of that bubble region, I get "neighbor list overflow" error,
which is quite certain. On the contrary, if I use "neighbor_modify exclude
type 2" then the interactions between gas atoms with switching off. Right?
help how? the neigh_modify documentation is quite clear about what it does
and it can be used to modify which pairs are included or excluded from the
neighbor list or to enlarge the max number of neighbors per atom and
adjust the size of neighbor list tiles for efficient memory use. so please
re-read the neigh_modify docs carefully and then reformulate your message
into one (or more) specific questions that go beyond what is explained
already.
