Problem in pair_style hybride
I’m using hybrid pair_style to define interatomic interactions by using the following command in the latest version of lammps,
pair_style hybrid eam/alloy table spline 3001 table spline 3001
pair_coeff * * eam/alloy copper.alloy Cu NULL
pair_coeff 1 2 table a.pot He Cu 3.6
pair_coeff 2 2 table b.pot He He 3.6
But, I’m experiencing the following error,
lattice fcc $a origin 0.01 0.01 0.01 orient z 1 -1 -1 orient x 1 1 0 orient y 1 -1 2 spacing 1 1 1
lattice fcc 3.615 origin 0.01 0.01 0.01 orient z 1 -1 -1 orient x 1 1 0 orient y 1 -1 2 spacing 1 1 1
Lattice spacing in x,y,z = 3.615 3.615 3.615
read_restart restart.100000
WARNING: Restart file used different # of processors (…/read_restart.cpp:717)
triclinic box = (0.186085 -0.554397 -0.333127) to (613.3 142.233 138.083) with tilt (2.37761 22.8205 -1.29343)
10 by 4 by 3 MPI processor grid
ERROR: Unknown pair style (…/force.cpp:240)
Could anybody please direct me if i’m doing any wrong? Is it may be due to my older restart file?
Paul
I'm using hybrid pair_style to define interatomic interactions by using
But, I'm experiencing the following error,
(../read_restart.cpp:717)
ERROR: Unknown pair style (../force.cpp:240)
Could anybody please direct me if i'm doing any wrong?
​difficult to say. was that restart generated with a different pair style?​
​possible. you could try to convert the restart into a data file and then
use that as a starting point​.
The issue has been solved. It was due to my old restart file, lammps data file works fine.
Thanks.
