I want to simulate a pois flow between two parallel walls .when I calculate the velocity profile (I used
dump velocity),I find that the velocity profile is not similar to **parabolic** and my velocity profile is
completely flat.I attach the velocity profile in below. what is wrong with my input script file?
# 2-d LJ flow simulation
dimension 2
boundary p s p
atom_style atomic
neighbor 0.3 bin
neigh_modify delay 5
# create geometry
lattice hex 0.7
region box block 0 20 0 10 -0.25 0.25
create_box 3 box
create_atoms 1 box
mass 1 1.0
mass 2 1.0
mass 3 1.0
# LJ potentials
pair_style lj/cut 1.12246
pair_coeff * * 1.0 1.0 1.12246
# define groups
region 1 block INF INF INF 1.25 INF INF
group lower region 1
region 2 block INF INF 8.75 INF INF INF
group upper region 2
group boundary union lower upper
group flow subtract all boundary
set group lower type 2
set group upper type 3
# initial velocities
compute mobile flow temp
velocity flow create 1.0 482748 temp mobile
fix 1 all nve
fix 2 flow temp/rescale 200 1.0 1.0 0.02 1.0
fix_modify 2 temp mobile
# Poiseuille flow
velocity boundary set 0.0 0.0 0.0
fix 3 lower setforce 0.0 0.0 0.0
fix 4 upper setforce 0.0 0.0 0.0
fix 6 flow addforce 0.5 0.0 0.0
fix 7 all enforce2d
# Run
timestep 0.003
thermo 500
thermo_modify temp mobile
dump 1 all custom 10000 traj_nvt.lammpstrj y vx
dump 3 all image 10000 image.*.PPM type type zoom 1.6 adiam 1.5
run 100000
Hi, You used a big force (fix 6 flow addforce 0.5 0.0 0.0) , you can use this command:
fix 6 flow addforce 0.05 0.0 0.0
Good Luck
why repost a question for which you already received an answer and without any discussion of that suggestion?
please note, that your inquiry is not really a question about LAMMPS, but rather about the science you are doing. this is something that you should first and foremost discuss with your adviser or whoever is consulting you on doing good and correct MD simulations. the focus of the mailing list is to solve LAMMPS specific problems, e.g. where LAMMPS is not working correctly.
thanks for your understanding,
