Problem on "ERROR: Invalid atom type 2 in Masses section of data file: 1 12.011"
I am currently using LAMMPS 64-bit 21Nov2023 version.
I am restarting a file that has been relaxed in p p p boundaries. I restarted this to change the boundary conditions.
I also want to read a data file into this, but keep getting “ERROR: Invalid atom type 2 in Masses section of data file: 1 12.011”
If I set the offset to 0 0 0 0 0, this works. However, what I want is to have two different particle types, one for the atoms from the restart and the other from the read_data file.
###The start of the code is like this:
read_restart restart_relaxed.equil
change_box all x final 0 39.27 y final 0 39.27 z final 0 70 boundary p p f units box
read_data data_carbon.data add append offset 1 0 0 0 0
###my data_carbon.data file is like this:
LAMMPS data file via write_data, version 21 Nov 2023, timestep = 0, units = metal
383 atoms
1 atom types
0 39.27 xlo xhi
0 39.27 ylo yhi
0 70 zlo zhi
Masses
1 12.011
Atoms # atomic
1 1 18.7425 13.3875 63.3675 0 0 0
2 1 22.3125 13.3875 63.3675 0 0 0
3 1 14.28 16.064999999999998 62.474999999999994 0 0 0
4 1 16.064999999999998 14.28 62.474999999999994 0 0 0
I tried to read the document about read_data command, but I cannot fully understand how to load the data file as separate particle type apart from the ones from the restart.
Thank you.
The problem originates with your “read_restart” command. The number of total atom types (and bond types, angle types etc.) is locked in when the simulation box is created. That happens during read_restart and you cannot change that.
The only way to change the number of atom types is by converting the restart file to a data file and then use the read_data command with the suitable extra/* commands to add the necessary types for the second data file, e.g. “extra/atom/types 1”.
Thank you sir for the detailed reply. I used extra/atom/types 1 and now it is working.
I guess my previous relaxation is usuless and have to relax all over again after read_data
Thank you
Sincreely,
Jones
