Hi all,
I was just trying to do some uniaxial tension test by using fix_deform and as a specimen sample I took single crystal Al. I use the available lamps script at https://icme.hpc.msstate.edu/mediawiki/index.php/Uniaxial_Tension
But, surprisingly I do not see any fracture even after the strain value of over 200%. The sample is stretched unusually at that high strain. I have seen a recent post about this type of behaviour but do not see any comments over it.
Could anybody please make some suggestion what I’m missing.
Thanks for your help in advance.
O
# Input file for uniaxial tensile loading of single crystal aluminum
# Mark Tschopp, November 2010
# ------------------------ INITIALIZATION ----------------------------
atom_style atomic
variable latparam equal 4.05
# ----------------------- ATOM DEFINITION ----------------------------
lattice fcc ${latparam}
region whole block 0 10 0 10 0 10
create_box 1 whole
lattice fcc ${latparam} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
create_atoms 1 region whole
# ------------------------ FORCE FIELDS ------------------------------
pair_style eam/alloy
pair_coeff * * Al99.eam.alloy Al
# ------------------------- SETTINGS ---------------------------------
compute csym all centro/atom fcc
compute peratom all pe/atom
