Problem using Tri and cylindrical
Hello dear LAMMPS users,
I am having a problem with a simulation, I am using an npt ensemble with a triclinical (tri) barostat because of the type of material, when I define the region to be a prism it works flawless.
Now I want to do the same type of simulation but on a cylindrical nanowire. I use an identical script where only the region definition is changed from prism to cylinder. The atom creation is done fine but right after that I obtain this error:
ERROR: Can not specify Pxy/Pxz/Pyz in fix nvt/npt/nph with non-triclinic box (…/fix_nh.cpp:395)
Can someone enlighten me why does this happens? Is it because the faces of the box are not aligned anymore to the faces of the bulk? Is there a workaround this error without having to declare as iso/aniso?
Thank you so much for your kindness and help,
Mario Muralles
box (../fix_nh.cpp:395)
​the error message is self-explanatory. you obviously have not changed your
simulation box to allow triclinic deformation.
​axel.​
Thank you for your prompt response,
Just for future references I worked around this by defining a prism vacuum box and inside it the cylinder containing the atoms.
Thanks again,
Mario
