I am trying to build LAMMPS with Python support and it works for the most part for my tests. Calling LAMMPS from Python works fine (including PyLammps) and Python commands works fine too, but when I try to callback to LAMMPS, errors happen. Here is the situation:
in2.python:
python loop input 4 10 1.0 -4.0 SELF format iffp file funcs.py
python loop invoke
funcs.py:
def loop(N,cut0,thresh,lmpptr):
print “LOOP ARGS”,N,cut0,thresh,lmpptr
from lammps import lammps
log.lammps:
LAMMPS (31 Mar 2017)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (…/comm.cpp:90)
python loop invoke
Output on console:
~/lammps/examples/python$ …/…/src/lmp_wheeler -in in2.python
LOOP ARGS 10 1.0 -4.0 <PyCObject object at 0x7f0b4cbd6620>
ERROR on proc 0: Python function evaluation failed (…/python.cpp:253)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1
system msg for write_line failure : Bad file descriptor
Could anyone help me please? Thanks a lot!
*in2.python:*
python loop invoke
*funcs.py:*
print "LOOP ARGS",N,cut0,thresh,lmpptr
*log.lammps:*
(../comm.cpp:90)
python loop invoke
*Output on console:*
~/lammps/examples/python$ ../../src/lmp_wheeler -in in2.python
(../comm.cpp:90)
ERROR on proc 0: Python function evaluation failed (../python.cpp:253)
please update LAMMPS to the lastest patch, but at least to version 19 May
2017.
