Hi all,
I'd like to access the particle's diameter, but I get errors which I don't understand and I hope you can help and explain why my script doesn't work...
If there are N particles in a volume, I'd like to access the particles diameter, depending on its z-coordinate. I was thinking of using a loop for looping over the particles' ID and then request with a boolean operator the z-coordinate to give it a new diameter.
Here an example; to control the values of the variables I used 3 different lines to output some values,
variable N equal atoms
compute zpos all property/atom z
variable zKoord atom c_zpos
label loop
variable i loop N
1) print ${zKoord[i]}
2) variable Z equal v_zKoord[i]
print $Z
3) variable Z equal c_zpos[i]
print $Z
if Z < 1 then "set atom $i diameter 0.1" elife (Z >= 1 & Z < 2) "set atom $i diameter 0.2" else "set atom $i diameter 0.3"
next i
jump in.script loop
but attempting that I got an error for each line.
Line 1) Error: Substitution for illegal variable
Line 2) Error: Non digit character between brackets in input command
Line 3) Error: Non digit character between brackets in input command
Why does it not work like I want to?
Thanks in advance,
kind regards,
Sebastian
