Problem with Berendsen temperature and pressure control
Hi, all
I try to equilibrate the simulation cell with Berendsen temperature and pressure control. Then I use command like :
Hi, all
timestep 0.005
velocity all create 600 376137 dist Gaussian
fix 1 all nve
fix 2 all temp/berendsen 300.0 300.0 0.5
fix 3 all press/berendsen iso 0.0 0.0 5.0
run 30000
However, the results show that the cell expanded dramatically during
equilibration, which is not expected. Need your help to found the mistake
difficult to say with such limited information.
the mistake is likely due to a combination of three issues that are
not suitable handled:
- your initial geometry is bad or the density of your initial geometry
is too high or your potential parameters not suitable or simply
incorrect leading to very high initial pressure and potential energy
- you are using fix press/berendsen right away (better to run for a
while without volume adjustments and turn it on later, especially)
- you have too short a relaxation time (when starting from a very
high-pressure initial state, the simulation cell will expand too
quickly and then it will take a very long time until you recover an
equilibrium volume/density. this is a deficiency of the berendsen
algorithm by itself and due to the fact that expansion has no barrier
while compression requires atoms rearrangements)).
Also, what units are you using? 5.0 for press damping
would be way too short for real, but OK for LJ or metal.
You can also monitor thermo output (say every 5 steps
at the beginning) and see if the pressure is dramatically
high. If so it will push your box to be very large. And
it won’t stop until the pressure drops below your target.
I am using metal units with timestep 0.005
Here are the thermo output
Step Temp PotEng Pxx Pyy Pzz
0 600 -2105908.8 -27644.34 -29965.759 -45951.097
5 491.91554 0 -126.7345 -143.39485 -131.0186
10 482.50976 0 -133.10779 -150.60596 -137.60733
15 473.56497 0 -140.38791 -158.84311 -145.13354
20 465.05856 0 -148.76425 -168.32059 -153.79303
25 458.08825 -12.33533 -155.96773 -178.7153 -159.78392
30 29275.131 4493.3669 51135.045 7635.3225 47767.219
The potential energy turn to 0 just after the simulation begin, but it’s strange that the system can be equilibrated with Nose-Hoover thermostat and barostat(NPT), and without any expansion. here is the corresponding output.
5 256.20591 -2086877.6 -5250.8517 -16162.74 -29422.906
10 243.97896 -2086188.4 -1162.3909 -30646.344 -22442.886
15 297.09628 -2089104.3 -9097.0808 -30328.588 -31436.992
20 303.07141 -2089498 -11048.486 -27708.848 -26192.648
25 317.21551 -2090339.8 -12832.395 -26882.382 -23973.068
30 294.44988 -2089128.1 -11712.894 -26817.628 -23501.67
35 306.03206 -2089825.8 -6337.311 -31135.224 -19820.944
40 292.39328 -2089109.9 -1245.6545 -22868.901 -19019.411
45 312.48164 -2090250 1698.4996 -15156.587 -16029.235
50 311.66776 -2090221.5 6118.1326 -10041.203 -12482.688
55 309.27726 -2090103.4 8666.5804 -11529.919 -13431.579
60 306.80278 -2089982.2 12174.344 -13811.524 -12095.79
65 305.64347 -2089930.9 11700.919 -11511.043 -12280.999
70 310.20745 -2090195.4 8621.3057 -9748.1374 -10872.36
75 308.75486 -2090129.2 5914.8068 -13052.945 -9548.9892
80 302.87402 -2089817.4 3816.4902 -17024.934 -10042.464
85 308.34288 -2090138.7 4032.2649 -18706.622 -9436.3035
90 301.17041 -2089764.8 5655.9022 -13865.015 -8308.9963
95 300.33894 -2089736.6 8181.1731 -9355.3081 -7089.3513
100 309.64968 -2090259.2 10779.477 -9907.8953 -6185.4319
105 311.44141 -2090368.1 13612.33 -10327.685 -6178.7306
110 310.00855 -2090307 16794.254 -7548.9427 -5214.3328
this is not strange at all. as i already mentioned, there is a
systematic deficiency in berendsen algorithms, and your initial
configuration and settings exposes it.
nose-hoover uses a different mechanism than berendsen to manipulate
temperature and volume of your system, that is much more indirect and
those less likely to cause unphysical behavior. judging from the
output below, i still think that there is something not quite right.
your initial configuration and settings seems to indicate an extremely
incompressible medium and the pressure values hint at using an
isotropic volume relaxation for a system, that is anisotropic.
as mentioned many times before, MD follows the GI-GO principle (=
garbage in, garbage out). in other words, if you feed LAMMPS
unreasonable or unsuitable input, you must not expect reasonable
output. computer software does not reason, it blindly follows what you
ask it to do.
Something very bad happened to the barostat during the first 5 timesteps. Nothing after this point can possibly be right.
Clearly, you started the system out with the volume somewhat too large (P ~ -30kbar). After 5 steps, the volume has become huge (small negative pressure, PE=0). In between, the Berendsen barostat probably made the volume extremely small, which caused the subsequent explosion. In order to solve the problem, you need to bring the system to its equilibrium volume gently. Here are some ways to do this:
  1. Increase value of Pdamp by a lot
  2. Use the modulus keyword to enter the correct bulk modulus. (default value is 10.0 bar in metal units, which is probably many orders of magnitude too soft)
  3. Ramp the target pressure from the current value to zero over the duration of the simulaiton
Putting that all together, I suggest:
fix 3 all press/berendsen iso -30000 0.0 5.0 modulus 1000.0
Aidan
