Problem with bond atom missing
Sorry to bother you. Recently I’ve run a lammps file and met problems with Bond atoms 6239 6389 missing on proc 3 at step 11646. I really hope you can help me to see what causes such fault?
Here is my in file:
log log.0923 run fix
units real
atom_style full
pair_style lj/cut/coul/long 13
bond_style harmonic
angle_style harmonic
dihedral_style harmonic
improper_style cvff
kspace_style ewald 0.0001
read_data 0923.data
neighbor 5.0 bin #5 ai
group layer1 id 7790:14005
fix 2a layer1 setforce 0.0 0.0 0.0
fix 1 all nvt temp 298.0 298.0 100.0
timestep 0.01
minimize 0 1.0e-7 100000 1000000
write_data aftermin.data
thermo_style multi
thermo 1000
dump 2 all image 5000 image.*.jpg type type &
zoom 1.5 center d 0.5 0.5 0.5
dump 3 all atom 10000 dump.%
timestep 0.1
run 10000
timestep 0.5
run 50000
write_data nvt25ps.data
See the Section_errors.html doc page of the manual.
It comments on all error messages.
It says:
*Bond atoms %d %d missing on proc %d at step %ld*
The 2nd atom needed to compute a particular bond is missing on this processor. Typically this is because the pairwise cutoff is set too short or the bond has blown apart and an atom is too far away.
Doesn’t it strike you as odd, that this happens briefly after you increase the timestep to 0.5fs?
Axel.
