Dear Lammps experts,
I have a problem in stretching of the anatase in tenisle test. Actuallz, I think that as I apply the periodic boundarz conditions in all x,y,z directions I cannot see the stretching of the sample.Neverhterles,I cannot omit the periodic boundary conditions becaue of the type of phase field computation.
Please let me know whether you have any suggestion.
input file
#Phase 1 ------------------------------------------Simulation main setup-------------------------------------------------
units real
atom_style charge
variable lz0 equal 60
#simulation box
region box block 0 15.144 0 11.358 0.0 70 units box
create_box 2 box #2 is number of atoms
it was very difficult to finally find these positions
lattice custom 1 a1 3.786 0.00000 0.00000 a2 0.0000 3.786 0.00000 a3 0 0 9.514 &
basis 0.0000 0.2500 0.3750 &
basis 0.0000 0.7500 0.6250 &
basis 0.5000 0.7500 0.8750 &
basis 0.5000 0.2500 0.1250 &
basis 0.0000 0.0000 0.1700 &
basis 0.0000 0.7500 0.4200 &
basis 0.5000 0.2500 0.3300 &
basis 0.5000 0.7500 0.0800 &
basis 0.500 0.5000 0.6700 &
basis 0.500 0.2500 0.9200 &
basis 0.000 0.7500 0.8300 &
basis 0.000 0.2500 0.5800
mass 1 47.86000
mass 2 15.99940
#Phase 2 -------------------------------------------------------tensile model design---------------------------------------------------------
region top_edge block 0 15.144 0 11.358 58 ${lz0} units box
create_atoms 2 region top_edge &
basis 1 1 &
basis 2 1 &
basis 3 1 &
basis 4 1 &
basis 5 2 &
basis 6 2 &
basis 7 2 &
basis 8 2 &
basis 9 2 &
basis 10 2 &
basis 11 2 &
basis 12 2
group top_edge region top_edge
set type 1 charge 2.196
set type 2 charge -1.098
#group model union particle substrate
region middle block 0 15.144 0 11.358 2 58 units box
create_atoms 2 region middle &
basis 1 1 &
basis 2 1 &
basis 3 1 &
basis 4 1 &
basis 5 2 &
basis 6 2 &
basis 7 2 &
basis 8 2 &
basis 9 2 &
basis 10 2 &
basis 11 2 &
basis 12 2
group middle region middle
region bottom_edge block 0 15.144 0 11.358 0 2 units box
create_atoms 2 region bottom_edge &
basis 1 1 &
basis 2 1 &
basis 3 1 &
basis 4 1 &
basis 5 2 &
basis 6 2 &
basis 7 2 &
basis 8 2 &
basis 9 2 &
basis 10 2 &
basis 11 2 &
basis 12 2
group bottom_edge region bottom_edge
#Phase 3----------------------------------------Buckingham Potential-----------------------------------------------
pair_style buck/coul/long 15.0
pair_coeff 1 1 717647.40 0.154 121.067
pair_coeff 1 2 391049.10 0.194 290.331
pair_coeff 2 2 271716.30 0.234 696.888
neighbor 2.0 bin # skin distance for real units is by default 2.0
kspace_style pppm 0.0001
#----Phase 5-------------------------------------Initial Equilibration at 300K: you can apply NVT or NPT----------------------------------------
timestep 1.0 # or 2
velocity all create 300 12345 mom yes rot no
fix 1 middle nvt temp 300.0 300.0 100.0
fix 2 bottom_edge setforce 0.0 0.0 0.0
fix 3 top_edge setforce 0.0 0.0 0.0
thermo 100
run 3000
unfix 1
#----Phase 6---------------------------------------tension phase: NVT and NVE are not allowd because of constant volume during stretching--------------------
variable rate equal 0.01
velocity top_edge ramp vz 0 {rate} z 58 59 sum yes
#fix 4 top_edge move linear 0 0 {rate} units box
#fix 5 middle nve !Achtung! volume is not constant during stretching
fix 6 middle temp/rescale 100 300.0 300.0 10.0 1.0
compute stpa middle stress/atom NULL
compute stgb middle reduce sum c_stpa[3]
variable szz equal c_stgb/vol
thermo 100
thermo_style custom step lx xhi v_szz temp
dump 2 all xyz 100 dump.txt
run 5000
