Dear Lammps users,
I want to use the compute group/group command to obtain the energy between two groups of atoms, and choose the SPC/E water model as a test.
compute WW oxygen group/group hydrogen
This command is set to calculate the energy between oxygen and hydrogen. Since kspace is no by default, this command will only generate the pairwise LJ 12-6 energy
system.in (756 Bytes)
system.in.settings (109 KB)
system.in.init (304 Bytes)
system.data (191 KB)
H2O.txt (550 Bytes)
system.in.charges (45.9 KB)
Dear Lammps users,
This command is set to calculate the energy between oxygen and hydrogen. Since kspace is no by default, this command will only generate the pairwise LJ 12-6 energy.
that is not correct. with the “pair yes” setting, it will also contain the real-space part of the coulomb interactions. This is what you are seeing.
Axel.
Dear Axel,
Thanks very much for your reply.
Best wishes,
Wei
