Hello All,
I am using the elastic constant scripts to test force field of crystal NaBH4, and always got problem about energy minimization: Stopping criterion = linesearch alpha is zero. The resulting elastic constant numbers are unreasonably high, and change hugely with the variable {up}.
As indicated by the script, I only changed the init.mod and potential.mod with my force field parameters, and kept in.elastic and displace.mod intact. And I have a data file for NaBH4 crystal structure.
Here is the beginning part of my data file:
#created by msxx2lammps.py
24 atoms
16 bonds
48 angles
16 impropers
3 atom types
1 bond types
2 angle types
1 improper types
0 6.0509 xlo xhi
0 6.0509 ylo yhi
0 6.0509 zlo zhi
0 0 0 xy xz yz
Masses
1 10.811000 # B
2 1.007940 # H
3 22.989769 # Na
Bond Coeffs
id K r0
1 XX XX # B-H
Angle Coeffs
id K theta0
1 cosine/squared XX XX # H-B-H
2 class2 XX XX XX XX
BondBond Coeffs
1 skip
2 class2 XX XX XX
BondAngle Coeffs
1 skip
Atoms
id mol-id type q x y z
1 1 3 1.000000 0.000000 0.000000 0.000000
2 2 3 1.000000 0.000000 3.025450 3.025450
My potential.mod file:
NOTE: This script can be modified for different pair styles
See in.elastic for more info.
Choose potential
pair_style buck/coul/cut 10.0
pair_coeff 1 3 XX XX XX # B-Na
pair_coeff 2 3 XX XX XX # H-Na
pair_coeff 1 2 XX XX XX # B-H
pair_coeff 1 1 XX XX XX # B-B
pair_coeff 2 2 XX XX XX # H-H
pair_coeff 3 3 XX XX XX # Na-Na
bond_style harmonic
bond_coeff XX XX XX XX # B-H
angle_style hybrid cosine/squared class2
angle_coeff 1 cosine/squared XX XX # H-B-H
angle_coeff 2 class2 XX XX XX XX
angle_coeff 2 class2 bb XX XX XX
angle_coeff 2 class2 ba XX XX XX XX
improper_style class2
improper_coeff XX XX XX # Ei
improper_coeff * aa XX XX XX XX XX XX#Eaa
Setup neighbor style
neighbor 1.0 nsq
neigh_modify once no every 1 delay 0 check yes
Setup minimization style
min_style cg
min_modify dmax ${dmax} line quadratic
dump 1 all xyz 1 all.Traj.xyz
Setup output
thermo 1
thermo_style custom step temp pe press pxx pyy pzz pxy pxz pyz lx ly lz vol
thermo_modify norm no
Here is part of my output file:
LAMMPS (11 Jun 2012)
Scanning data file …
4 = max bonds/atom
12 = max angles/atom
4 = max impropers/atom
Reading data file …
triclinic box = (0 0 0) to (6.0509 6.0509 6.0509) with tilt (0 0 0)
2 by 2 by 2 MPI processor grid
24 atoms
16 bonds
48 angles
16 impropers
Finding 1-2 1-3 1-4 neighbors …
4 = max # of 1-2 neighbors
3 = max # of 1-3 neighbors
3 = max # of 1-4 neighbors
4 = max # of special neighbors
Replicating atoms …
triclinic box = (0 0 0) to (36.3054 36.3054 36.3054) with tilt (0 0 0)
5184 atoms
3456 bonds
10368 angles
3456 impropers
Setting up minimization …
Memory usage per processor = 8.35428 Mbytes
Step Temp PotEng Press Pxx Pyy Pzz Pxy Pxz Pyz Lx Ly Lz Volume
0 0 -364557.73 -120175.41 -120178.35 -120178.35 -120169.54 -1.7608711 3.5177277 -3.5258032 36.3054 36.3054 36.3054 47853.497
1 0 -364582.88 -120071.98 -120074.92 -120074.92 -120066.11 -1.7613994 3.518783 -3.5268609 36.301769 36.301769 36.30177 47839.142
2 0 -364608 -119968.45 -119971.39 -119971.39 -119962.59 -1.7619279 3.5198387 -3.5279191 36.298139 36.298139 36.298139 47824.791
3 0 -364633.1 -119864.83 -119867.76 -119867.76 -119858.97 -1.7624565 3.5208948 -3.5289777 36.294508 36.294508 36.294509 47810.443
4 0 -364658.16 -119761.11 -119764.04 -119764.04 -119755.25 -1.7629855 3.5219514 -3.5300367 36.290878 36.290878 36.290879 47796.097
5 0 -364683.21 -119657.3 -119660.23 -119660.23 -119651.44 -1.7635146 3.5230084 -3.5310961 36.287247 36.287247 36.287249 47781.754
6 0 -364708.22 -119553.39 -119556.32 -119556.32 -119547.54 -1.7640439 3.5240658 -3.532156 36.283617 36.283617 36.283618 47767.414
7 0 -364733.21 -119449.38 -119452.31 -119452.31 -119443.53 -1.7645734 3.5251236 -3.5332163 36.279986 36.279986 36.279988 47753.077
8 0 -364758.17 -119345.28 -119348.21 -119348.21 -119339.43 -1.7651032 3.5261819 -3.534277 36.276356 36.276356 36.276358 47738.743
9 0 -364783.1 -119241.08 -119244.01 -119244.01 -119235.24 -1.7656331 3.5272406 -3.5353381 36.272725 36.272725 36.272728 47724.412
10 0 -364808.01 -119136.79 -119139.71 -119139.71 -119130.94 -1.7661633 3.5282997 -3.5363997 36.269095 36.269095 36.269097 47710.083
45 0 -365401.74 -116586.86 -116589.75 -116589.75 -116581.08 -1.7790401 3.5540228 -3.5621826 36.181361 36.181361 36.18137 47364.7
46 0 -365401.74 -116586.86 -116589.75 -116589.75 -116581.08 -1.7790401 3.5540228 -3.5621826 36.181361 36.181361 36.18137 47364.7
47 0 -365401.74 -116586.86 -116589.75 -116589.75 -116581.08 -1.7790401 3.5540228 -3.5621826 36.181361 36.181361 36.18137 47364.7
48 0 -365401.74 -116586.86 -116589.75 -116589.75 -116581.08 -1.7790401 3.5540228 -3.5621826 36.181361 36.181361 36.18137 47364.7
49 0 -365401.74 -116586.86 -116589.75 -116589.75 -116581.08 -1.7790401 3.5540228 -3.5621826 36.181361 36.181361 36.18137 47364.7
50 0 -365401.74 -116586.86 -116589.75 -116589.75 -116581.08 -1.7790401 3.5540228 -3.5621826 36.181361 36.181361 36.18137 47364.7
Loop time of 5.70808 on 8 procs for 50 steps with 5184 atoms
Minimization stats:
Energy initial, next-to-last, final =
-364557.732124 -365401.742662 -365401.742662
Force two-norm initial, final = 145267 139968
Force max component initial, final = 83871.8 80812.3
Final line search alpha, max atom move = 5.76226e-19 4.65661e-14
Iterations, force evaluations = 50 351
Pair time () = 4.57708 (80.1861)
Bond time () = 0.14231 (2.49313)
Neigh time () = 0 (0)
Comm time () = 0.414695 (7.26505)
Outpt time () = 0.458084 (8.02518)
Other time () = 0.115907 (2.03058)
Nlocal: 648 ave 648 max 648 min
Histogram: 8 0 0 0 0 0 0 0 0 0
Nghost: 5945 ave 5945 max 5945 min
Neighs: 192348 ave 192951 max 191745 min
Histogram: 1 2 1 0 0 0 0 1 2 1
Total # of neighbors = 1538784
Ave neighs/atom = 296.833
Ave special neighs/atom = 3.33333
Neighbor list builds = 0
Dangerous builds = 0
System init for write_restart …
Reading restart file …
triclinic box = (0.0620197 0.0620197 0.0620152) to (36.2434 36.2434 36.2434) with tilt (0 0 0)
5184 atoms
3456 bonds
10368 angles
3456 impropers
Changing box …
triclinic box = (0.0620197 0.0620197 0.0620152) to (36.2289 36.2434 36.2434) with tilt (0 0 0)
Memory usage per processor = 9.26149 Mbytes
50 0 -316928.99 -92888.561 -78970.343 -99852.01 -99843.33 -1.7981747 3.5424088 -0.61077155 36.166888 36.181361 36.18137 47345.754
51 0 -316928.99 -92888.561 -78970.343 -99852.01 -99843.33 -1.7981747 3.5424088 -0.61077155 36.166888 36.181361 36.18137 47345.754
Loop time of 0.691855 on 8 procs for 1 steps with 5184 atoms
Minimization stats:
-316928.98531 -316928.98531 -316928.98531
Force two-norm initial, final = 406.541 406.541
Force max component initial, final = 16.0143 16.0143
Final line search alpha, max atom move = 7.26944e-14 1.16415e-12
Iterations, force evaluations = 1 41
Pair time () = 0.550613 (79.585)
Bond time () = 0.0167682 (2.42366)
Comm time () = 0.112031 (16.1929)
Outpt time () = 0 (0)
Other time () = 0.0124428 (1.79847)
Nlocal: 648 ave 726 max 582 min
Histogram: 2 0 0 0 4 0 0 0 0 2
Nghost: 5945 ave 6011 max 5867 min
Histogram: 2 0 0 0 0 4 0 0 0 2
Neighs: 198828 ave 223296 max 178117 min
Total # of neighbors = 1590624
Ave neighs/atom = 306.833
5184 atoms
3456 bonds
10368 angles
3456 impropers
Changing box …
triclinic box = (0.0620197 0.0620197 0.0620152) to (36.2579 36.2434 36.2434) with tilt (0 0 0)
Memory usage per processor = 9.95253 Mbytes
50 0 -365369.04 -116884.27 -117237.59 -116711.94 -116703.27 -1.7597702 3.565684 -6.7136085 36.195833 36.181361 36.18137 47383.646
51 0 -365369.04 -116884.27 -117237.59 -116711.94 -116703.27 -1.7597702 3.565684 -6.7136085 36.195833 36.181361 36.18137 47383.646
52 0 -365369.04 -116884.27 -117237.59 -116711.94 -116703.27 -1.7597702 3.565684 -6.7136085 36.195833 36.181361 36.18137 47383.646
Loop time of 1.36695 on 8 procs for 2 steps with 5184 atoms
Minimization stats:
-365369.040519 -365369.040519 -365369.040519
Force two-norm initial, final = 304.988 304.988
Force max component initial, final = 5.96586 5.96586
Final line search alpha, max atom move = 9.75679e-14 5.82077e-13
Iterations, force evaluations = 2 78
Pair time () = 1.03125 (75.442)
Bond time () = 0.0316614 (2.31621)
Comm time () = 0.279322 (20.434)
Outpt time () = 0.00942358 (0.68939)
Other time () = 0.0152877 (1.11839)
Nlocal: 648 ave 775 max 557 min
Histogram: 1 0 3 0 0 3 0 0 0 1
Nghost: 5945 ave 6036 max 5818 min
Histogram: 1 0 0 0 3 0 0 3 0 1
Neighs: 198612 ave 237727 max 170622 min
Thank you very much!
Ping
