I encountered a problem with variable force->qqrd2e. Previously, I use force->qqr2e in my code to convert unit and it works fine. Recently, I found it might be better to used qqrd2e. But when I replaced qqr2e with qqrd2e, the computation crashed. I print the value of qqrd2e on the screen and found it was zero. I have included “force.h” in the header file zone but it doesn’t work. Hope for suggestions.
By the way, even if I put dieletric command in the input file, it still doesn’t work.
Thanks in advance.
Han
