Problem with intel lrt yes and minimize
Dear LAMMPS developers,
my colleague and i ran in the problem that as soon we are using intel package with the option "lrt yes" that the minimization (min_style cg) does not work properly.
I can reproduce the behavior with a modified version of the example script "in.phosphate" (see below for the script, commands, lammps-version).
As soon as we are not using "lrt yes" the minimization takes place correctly.
"-sf intel -pk intel 0 omp 1 mode double lrt yes" <= no minimizations steps
"-sf intel -pk intel 0 omp 1 mode double" <= OK
"" <= OK
I looked through the Documentation but couldn't find any restrictions for the combination of "-sf intel -pk intel 0 omp 1 lrt yes" and "minimize".
So it might be an error or something one should warn about, if you could confirm that there is no user-error on my side and you can reproduce the behavior i can write an issue on github.
Sincerely,
Michael King
Note:
There is a small different between icc-2017 and icc-2018 in "mode mixed".
# Testsystem
# \{LAMMPSFOLDER\}/examples/accelerate/data\.phosphate \# {LAMMPSFOLDER}/examples/accelerate/in.phosphate (modified, see below)
variable x index 1
variable y index 1
variable z index 1
variable t index 100
atom_style charge
read_data data.phosphate
replicate $x $y $z
pair_style lj/cut/coul/long 15.0
pair_coeff 1 1 0.0 0.29
pair_coeff 1 2 0.0 0.29
pair_coeff 1 3 0.000668 2.5738064
pair_coeff 2 2 0.0 0.29
pair_coeff 2 3 0.004251 1.91988674
pair_coeff 3 3 0.012185 2.91706967
kspace_style pppm 1e-5
neighbor 2.0 bin
fill in a
thermo 100
timestep 0.001
min_style cg
min_modify line quadratic
minimize 1e-6 1e-6 100 100
# LAMMPS
LAMMPS (16 Mar 2018) & LAMMPS (11 May 2018)
make yes-molecule yes-kspace yes-user-intel
make -j4 intel_cpu
# Machine
Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
Red Hat Enterprise Linux Server release 7.4 (Maipo)
compiler/intel/18.0 mpi/impi/2018-intel-18.0 numlib/mkl/2018
compiler/intel/17.0 mpi/impi/2017-intel-17.0 numlib/mkl/2017
# Commands
module purge
module load compiler/intel/18.0 mpi/impi/2018-intel-18.0 numlib/mkl/2018
mpirun -np 4 ./lmp_intel_cpu_icc18 -in in.phosphate.em -sf intel -pk intel 0 omp 1 mode double lrt yes -log log.icc18.intel-0_omp-1_lrt.lammps
mpirun -np 4 ./lmp_intel_cpu_icc18 -in in.phosphate.em -sf intel -pk intel 0 omp 1 mode double -log log.icc18.intel-0_omp-1.lammps
mpirun -np 4 ./lmp_intel_cpu_icc18 -in in.phosphate.em -log log.icc18.blank.lammps
module purge
module load compiler/intel/17.0 mpi/impi/2017-intel-17.0 numlib/mkl/2017
mpirun -np 4 ./lmp_intel_cpu_icc17 -in in.phosphate.em -sf intel -pk intel 0 omp 1 mode double lrt yes -log log.icc17.intel-0_omp-1_lrt.lammps
mpirun -np 4 ./lmp_intel_cpu_icc17 -in in.phosphate.em -sf intel -pk intel 0 omp 1 mode double -log log.icc17.intel-0_omp-1.lammps
mpirun -np 4 ./lmp_intel_cpu_icc17 -in in.phosphate.em -log log.icc17.blank.lammps
Michael,
it is indeed best to report this as an issue on github and specifically mention @wmbrownIntel to notify the principal author of the USER-INTEL package.
e-mails to the mailing list have a tendency to get lost, if not acted upon immediately.
thanks,
