Recently I developed a fix style for point induced dipole polarization model. The fix style uses post_force method to add additional force to atom->f. It also uses compute_scalar method to return added energy.
The code works fine when I run with 1, 2, 4 cores but it crashes when I run with 16 cores. Previously, someone encountered such problem when they had two fix styles which change the size of simulation box but I only have one fix/npt. Hope someone could give me an advice. Thanks!
Han.
Log file is as the following:
LAMMPS (15 May 2015)
Reading data file …
orthogonal box = (0 0 0) to (19.71 19.71 19.71)
2 by 2 by 4 MPI processor grid
reading atoms …
768 atoms
scanning bonds …
2 = max bonds/atom
scanning angles …
1 = max angles/atom
reading bonds …
512 bonds
reading angles …
256 angles
Finding 1-2 1-3 1-4 neighbors …
Special bond factors lj: 0 0 0
Special bond factors coul: 0 0 0
2 = max # of 1-2 neighbors
1 = max # of 1-3 neighbors
1 = max # of 1-4 neighbors
2 = max # of special neighbors
768 atoms in group tip4p_def
512 atoms in group hydrogen
256 atoms in group oxygen
Finding SHAKE clusters …
0 = # of size 2 clusters
0 = # of size 3 clusters
0 = # of size 4 clusters
256 = # of frozen angles
PPPM initialization …
extracting TIP4P info from pair style
G vector (1/distance) = 0.24176
grid = 15 15 15
stencil order = 5
estimated absolute RMS force accuracy = 0.00261389
estimated relative force accuracy = 7.87164e-06
using double precision FFTs
3d grid and FFT values/proc = 2156 256
Neighbor list info …
5 neighbor list requests
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 15.3092
Setting up run …
Memory usage per processor = 9.23639 Mbytes
Step Time tt Temp TempAve Press PressAve PEAve_Mo DensAve Volume order
0 0 0 447.29159 0 -23545.674 0 0 0 7657.0216 0.494379
ERROR on proc 7: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 14: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 4: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 5: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 13: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 5
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 7
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 14
ERROR on proc 1: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 6: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 8: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 11: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 4
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 13
ERROR on proc 10: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 12: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 15: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 6
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 8
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 11
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 15
ERROR on proc 0: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 2: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
ERROR on proc 9: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 10
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 12
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 2
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 9
ERROR on proc 3: Non-numeric box dimensions - simulation unstable (…/pppm_tip4p.cpp:77)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 3
Input file is as the following:
